查看: 781|回复: 0
热成像UVC相机的USB描述符
发表于 2025-10-28 18:21:37 | 显示全部楼层 |阅读模式
      =========================== USB Port1 ===========================
Connection Status        : 0x01 (Device is connected)
Port Chain               : 2-1-1
Properties               : 0x01
IsUserConnectable       : yes
PortIsDebugCapable      : no
PortHasMultiCompanions  : no
PortConnectorIsTypeC    : no
ConnectionIndex          : 0x01 (Port 1)
CompanionIndex           : 0
CompanionHubSymLnk      : USB#VID_2109&PID_0817#5&6da824a&0&16#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
CompanionPortNumber     : 0x01 (Port 1)
-> CompanionPortChain   : 2-16-1
      ========================== Summary =========================
Vendor ID                : 0x2BDF (Hangzhou Hikvision Digital Technology Co., Ltd.)
Product ID               : 0x0102
USB Version              : 2.0
Port maximum Speed       : High-Speed (Companion Port 2-16-1 supports SuperSpeed)
Device maximum Speed     : High-Speed
Device Connection Speed  : High-Speed
Self powered             : no
Demanded Current         : 100 mA
Used Endpoints           : 3
      ======================== USB Device ========================
        +++++++++++++++++ Device Information ++++++++++++++++++
Device Description       : USB Composite Device
Device Path              : \\?\USB#VID_2BDF&PID_0102#EA3377929#{a5dcbf10-6530-11d2-901f-00c04fb951ed} (GUID_DEVINTERFACE_USB_DEVICE)
Kernel Name              : \Device\USBPDO-11
Device ID                : USB\VID_2BDF&PID_0102\EA3377929
Hardware IDs             : USB\VID_2BDF&PID_0102&REV_0409 USB\VID_2BDF&PID_0102
Driver KeyName           : {36fc9e60-c465-11cf-8056-444553540000}\0029 (GUID_DEVCLASS_USB)
Driver                   : \SystemRoot\System32\drivers\usbccgp.sys (Version: 10.0.19041.5794  Date: 2025-05-17)
Driver Inf               : C:\Windows\inf\usb.inf
Legacy BusType           : PNPBus
Class                    : USB
Class GUID               : {36fc9e60-c465-11cf-8056-444553540000} (GUID_DEVCLASS_USB)
Service                  : usbccgp
Enumerator               : USB
Location Info            : Port_#0001.Hub_#0005
Location IDs             : PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(1)#USB(1), ACPI(_SB_)#ACPI(PCI0)#ACPI(XHC_)#ACPI(RHUB)#ACPI(HS01)#USB(1)
Container ID             : {8c694ec7-2a8a-5dfc-a806-9ec7db86e755}
Manufacturer Info        : (标准 USB 主控制器)
Capabilities             : 0x94 (Removable, UniqueID, SurpriseRemovalOK)
Status                   : 0x0180600A (DN_DRIVER_LOADED, DN_STARTED, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER)
Problem Code             : 0
Address                  : 1
Power State              : D0 (supported: D0, D2, D3, wake from D0, wake from D2)
Child Device 1          : UVC Camera (USB 视频设备)
  Device Path 1          : \\?\USB#VID_2BDF&PID_0102&MI_00#7&16ff1baa&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global (STATIC_KSCATEGORY_VIDEO_CAMERA)
  Device Path 2          : \\?\USB#VID_2BDF&PID_0102&MI_00#7&16ff1baa&0&0000#{6994ad05-93ef-11d0-a3cc-00a0c9223196}\global (AM_KSCATEGORY_VIDEO)
  Device Path 3          : \\?\USB#VID_2BDF&PID_0102&MI_00#7&16ff1baa&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global (AM_KSCATEGORY_CAPTURE)
  Kernel Name            : \Device\000002ff
  Device ID              : USB\VID_2BDF&PID_0102&MI_00\7&16FF1BAA&0&0000
  Class                  : Camera
  Driver KeyName         : {ca3e7ab9-b4c3-4ae6-8251-579ef933890f}\0000 (GUID_DEVCLASS_CAMERA)
  Service                : usbvideo
  LocationPaths          : PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(1)#USB(1)#USBMI(0)  PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(1)#USB(1)#USB(1)  ACPI(_SB_)#ACPI(PCI0)#ACPI(XHC_)#ACPI(RHUB)#ACPI(HS01)#USB(1)#USBMI(0)  ACPI(_SB_)#ACPI(PCI0)#ACPI(XHC_)#ACPI(RHUB)#ACPI(HS01)#USB(1)#USB(1)
        +++++++++++++++++ Registry USB Flags +++++++++++++++++
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\usbflags\2BDF01020409
osvc                    : REG_BINARY 00 00
        ---------------- Connection Information ---------------
Connection Index         : 0x01 (Port 1)
Connection Status        : 0x01 (DeviceConnected)
Current Config Value     : 0x01 (Configuration 1)
Device Address           : 0x16 (22)
Is Hub                   : 0x00 (no)
Device Bus Speed         : 0x02 (High-Speed)
Number Of Open Pipes     : 0x02 (2 pipes to data endpoints)
Pipe[0]                  : EndpointID=3  Direction=IN   ScheduleOffset=0  Type=Interrupt  wMaxPacketSize=0x10    bInterval=8   -> 270 Bits/ms = 33750 Bytes/s
Pipe[1]                  : EndpointID=1  Direction=IN   ScheduleOffset=0  Type=Bulk       wMaxPacketSize=0x200   bInterval=0
Data (HexDump)           : 01 00 00 00 12 01 00 02 EF 02 01 40 DF 2B 02 01   ...........@.+..
                           09 04 01 02 03 01 01 02 00 16 00 02 00 00 00 01   ................
                           00 00 00 07 05 83 03 10 00 08 00 00 00 00 07 05   ................
                           81 02 00 02 00 00 00 00 00                        .........
        --------------- Connection Information V2 -------------
Connection Index         : 0x01 (1)
Length                   : 0x10 (16 bytes)
SupportedUsbProtocols    : 0x03
Usb110                  : 1 (yes, port supports USB 1.1)
Usb200                  : 1 (yes, port supports USB 2.0)
Usb300                  : 0 (no, port not supports USB 3.0) -> but Companion Port 2-16-1 does
ReservedMBZ             : 0x00
Flags                    : 0x00
DevIsOpAtSsOrHigher     : 0 (Device is not operating at SuperSpeed or higher)
DevIsSsCapOrHigher      : 0 (Device is not SuperSpeed capable or higher)
DevIsOpAtSsPlusOrHigher : 0 (Device is not operating at SuperSpeedPlus or higher)
DevIsSsPlusCapOrHigher  : 0 (Device is not SuperSpeedPlus capable or higher)
ReservedMBZ             : 0x00
Data (HexDump)           : 01 00 00 00 10 00 00 00 03 00 00 00 00 00 00 00   ................
    ---------------------- Device Descriptor ----------------------
bLength                  : 0x12 (18 bytes)
bDescriptorType          : 0x01 (Device Descriptor)
bcdUSB                   : 0x200 (USB Version 2.0)
bDeviceClass             : 0xEF (Miscellaneous)
bDeviceSubClass          : 0x02
bDeviceProtocol          : 0x01 (IAD - Interface Association Descriptor)
bMaxPacketSize0          : 0x40 (64 bytes)
idVendor                 : 0x2BDF (Hangzhou Hikvision Digital Technology Co., Ltd.)
idProduct                : 0x0102
bcdDevice                : 0x0409
iManufacturer            : 0x01 (String Descriptor 1)
Language 0x0409         : "HIK"
iProduct                 : 0x02 (String Descriptor 2)
Language 0x0409         : "Camera"
iSerialNumber            : 0x03 (String Descriptor 3)
Language 0x0409         : "EA3377929"
bNumConfigurations       : 0x01 (1 Configuration)
Data (HexDump)           : 12 01 00 02 EF 02 01 40 DF 2B 02 01 09 04 01 02   .......@.+......
                           03 01                                             ..
    ------------------ Configuration Descriptor -------------------
bLength                  : 0x09 (9 bytes)
bDescriptorType          : 0x02 (Configuration Descriptor)
wTotalLength             : 0x018C (396 bytes)
bNumInterfaces           : 0x02 (2 Interfaces)
bConfigurationValue      : 0x01 (Configuration 1)
iConfiguration           : 0x04 (String Descriptor 4)
Language 0x0409         : "Config 1"
bmAttributes             : 0x80
D7: Reserved, set 1     : 0x01
D6: Self Powered        : 0x00 (no)
D5: Remote Wakeup       : 0x00 (no)
D4..0: Reserved, set 0  : 0x00
MaxPower                 : 0x32 (100 mA)
Data (HexDump)           : 09 02 8C 01 02 01 04 80 32 08 0B 00 02 0E 03 00   ........2.......
                           05 09 04 00 00 01 0E 01 00 05 0D 24 01 10 01 51   ...........$...Q
                           00 00 6C DC 02 01 01 12 24 02 02 01 02 00 00 00   ..l.....$.......
                           00 00 00 00 00 03 00 00 00 0C 24 05 05 01 00 40   ..........$....@
                           02 00 00 00 09 1D 24 06 0A 41 76 9E A2 04 DE E3   ......$..Av.....
                           47 8B 2B F4 34 1A FF 00 3B 0F 01 02 04 FF 03 00   G.+.4...;.......
                           00 00 09 24 03 03 01 01 00 02 00 07 05 83 03 10   ...$............
                           00 08 05 25 03 10 00 09 04 01 00 01 0E 02 00 06   ...%............
                           0F 24 01 02 05 01 81 00 03 00 00 00 01 00 00 1B   .$..............
                           24 04 01 05 59 55 59 32 00 00 10 00 80 00 00 AA   $...YUY2........
                           00 38 9B 71 10 01 00 00 00 00 1E 24 05 01 00 00   .8.q.......$....
                           01 58 01 00 A0 80 02 00 A0 80 02 00 34 03 00 80   .X..........4...
                           1A 06 00 01 80 1A 06 00 1E 24 05 03 00 00 01 C4   .........$......
                           00 00 A0 80 02 00 A0 80 02 00 34 03 00 80 1A 06   ..........4.....
                           00 01 80 1A 06 00 1E 24 05 04 00 91 15 10 00 00   .......$........
                           A0 80 02 00 A0 80 02 00 34 03 00 80 1A 06 00 01   ........4.......
                           80 1A 06 00 1E 24 05 08 00 00 01 68 01 00 A0 80   .....$.....h....
                           02 00 A0 80 02 00 34 03 00 80 1A 06 00 01 80 1A   ......4.........
                           06 00 1E 24 05 09 00 CF 01 DC 00 00 A0 80 02 00   ...$............
                           A0 80 02 00 34 03 00 80 1A 06 00 01 80 1A 06 00   ....4...........
                           06 24 0D 01 01 04 1B 24 04 02 01 4E 56 31 32 00   .$.....$...NV12.
                           00 10 00 80 00 00 AA 00 38 9B 71 0C 01 00 00 00   ........8.q.....
                           00 1E 24 05 02 00 00 01 C0 00 00 A0 80 02 00 A0   ..$.............
                           80 02 00 34 03 00 80 1A 06 00 01 80 1A 06 00 06   ...4............
                           24 0D 01 01 04 07 05 81 02 00 02 00               $...........
        ------------------- IAD Descriptor --------------------
bLength                  : 0x08 (8 bytes)
bDescriptorType          : 0x0B (Interface Association Descriptor)
bFirstInterface          : 0x00 (Interface 0)
bInterfaceCount          : 0x02 (2 Interfaces)
bFunctionClass           : 0x0E (Video)
bFunctionSubClass        : 0x03 (Video Interface Collection)
bFunctionProtocol        : 0x00 (PC_PROTOCOL_UNDEFINED)
iFunction                : 0x05 (String Descriptor 5)
Language 0x0409         : "UVC Camera"
Data (HexDump)           : 08 0B 00 02 0E 03 00 05                           ........
        ---------------- Interface Descriptor -----------------
bDescriptorType          : 0x04 (Interface Descriptor)
bInterfaceNumber         : 0x00 (Interface 0)
bAlternateSetting        : 0x00
bNumEndpoints            : 0x01 (1 Endpoint)
bInterfaceClass          : 0x0E (Video)
bInterfaceSubClass       : 0x01 (Video Control)
bInterfaceProtocol       : 0x00
iInterface               : 0x05 (String Descriptor 5)
Data (HexDump)           : 09 04 00 00 01 0E 01 00 05                        .........
        ------- Video Control Interface Header Descriptor -----
bLength                  : 0x0D (13 bytes)
bDescriptorType          : 0x24 (Video Control Interface)
bDescriptorSubtype       : 0x01 (Video Control Header)
bcdUVC                   : 0x0110 (UVC Version 1.10)
wTotalLength             : 0x0051 (81 bytes)
dwClockFreq              : 0x02DC6C00 (48 MHz)
bInCollection            : 0x01 (1 VideoStreaming interface)
baInterfaceNr[1]         : 0x01 (Interface 1)
Data (HexDump)           : 0D 24 01 10 01 51 00 00 6C DC 02 01 01            .$...Q..l....
        -------- Video Control Input Terminal Descriptor ------
bDescriptorSubtype       : 0x02 (Input Terminal)
bTerminalID              : 0x02 (2)
wTerminalType            : 0x0201 (ITT_CAMERA)
bAssocTerminal           : 0x00 (Not associated with an Output Terminal)
iTerminal                : 0x00 (No String Descriptor)
Camera Input Terminal Data:
wObjectiveFocalLengthMin : 0x0000
wObjectiveFocalLengthMax : 0x0000
wOcularFocalLength       : 0x0000
bControlSize             : 0x03 (3 bytes)
bmControls               : 0x00, 0x00, 0x00
D0                      : 0   no -  Scanning Mode
D1                      : 0   no -  Auto-Exposure Mode
D2                      : 0   no -  Auto-Exposure Priority
D3                      : 0   no -  Exposure Time (Absolute)
D4                      : 0   no -  Exposure Time (Relative)
D5                      : 0   no -  Focus (Absolute)
D6                      : 0   no -  Focus (Relative)
D7                      : 0   no -  Iris (Absolute)
D8                      : 0   no -  Iris (Relative)
D9                      : 0   no -  Zoom (Absolute)
D10                     : 0   no -  Zoom (Relative)
D11                     : 0   no -  Pan (Absolute)
D12                     : 0   no -  Pan (Relative)
D13                     : 0   no -  Roll (Absolute)
D14                     : 0   no -  Roll (Relative)
D15                     : 0   no -  Tilt (Absolute)
D16                     : 0   no -  Tilt (Relative)
D17                     : 0   no -  Focus Auto
D18                     : 0   no -  Reserved
D19                     : 0   no -  Reserved
D20                     : 0   no -  Reserved
D21                     : 0   no -  Reserved
D22                     : 0   no -  Reserved
D23                     : 0   no -  Reserved
Data (HexDump)           : 12 24 02 02 01 02 00 00 00 00 00 00 00 00 03 00   .$..............
                           00 00                                             ..
        -------- Video Control Processing Unit Descriptor -----
bLength                  : 0x0C (12 bytes)
bDescriptorSubtype       : 0x05 (Processing Unit)
bUnitID                  : 0x05 (5)
bSourceID                : 0x01 (1)
wMaxMultiplier           : 0x4000 (163.84x Zoom)
bControlSize             : 0x02 (2 bytes)
D0                      : 0   no -  Brightness
D1                      : 0   no -  Contrast
D2                      : 0   no -  Hue
D3                      : 0   no -  Saturation
D4                      : 0   no -  Sharpness
D5                      : 0   no -  Gamma
D6                      : 0   no -  White Balance Temperature
D7                      : 0   no -  White Balance Component
D8                      : 0   no -  Backlight Compensation
D9                      : 0   no -  Gain
D10                     : 0   no -  Power Line Frequency
D11                     : 0   no -  Hue, Auto
D12                     : 0   no -  White Balance Temperature, Auto
D13                     : 0   no -  White Balance Component, Auto
D14                     : 0   no -  Digital Multiplier
D15                     : 0   no -  Digital Multiplier Limit
iProcessing              : 0x00 (No String Descriptor)
bmVideoStandards         : 0x09
D0                      : 1  yes -  None
D1                      : 0   no -  NTSC  - 525/60
D2                      : 0   no -  PAL   - 625/50
D3                      : 1  yes -  SECAM - 625/50
D4                      : 0   no -  NTSC  - 625/50
D5                      : 0   no -  PAL   - 525/60
D6                      : 0   no -  Reserved
D7                      : 0   no -  Reserved
Data (HexDump)           : 0C 24 05 05 01 00 40 02 00 00 00 09               .$....@.....
        --------- Video Control Extension Unit Descriptor -----
bLength                  : 0x1D (29 bytes)
bDescriptorSubtype       : 0x06 (Extension Unit)
bUnitID                  : 0x0A (ID 10)
guidExtensionCode        : {A29E7641-DE04-47E3-8B2B-F4341AFF003B}
bNumControls             : 0x0F (15 Controls)
bNrInPins                : 0x01 (1 Input Pin)
baSourceID[1]            : 0x02
bControlSize             : 0x04 (4 bytes)
bmControls               : 0xFF, 0x03, 0x00, 0x00
D0                      : 1  yes -  Vendor-Specific (Optional)
D1                      : 1  yes -  Vendor-Specific (Optional)
D2                      : 1  yes -  Vendor-Specific (Optional)
D3                      : 1  yes -  Vendor-Specific (Optional)
D4                      : 1  yes -  Vendor-Specific (Optional)
D5                      : 1  yes -  Vendor-Specific (Optional)
D6                      : 1  yes -  Vendor-Specific (Optional)
D7                      : 1  yes -  Vendor-Specific (Optional)
D8                      : 1  yes -  Vendor-Specific (Optional)
D9                      : 1  yes -  Vendor-Specific (Optional)
D10                     : 0   no -  Vendor-Specific (Optional)
D11                     : 0   no -  Vendor-Specific (Optional)
D12                     : 0   no -  Vendor-Specific (Optional)
D13                     : 0   no -  Vendor-Specific (Optional)
D14                     : 0   no -  Vendor-Specific (Optional)
D15                     : 0   no -  Vendor-Specific (Optional)
D16                     : 0   no -  Vendor-Specific (Optional)
D17                     : 0   no -  Vendor-Specific (Optional)
D18                     : 0   no -  Vendor-Specific (Optional)
D19                     : 0   no -  Vendor-Specific (Optional)
D20                     : 0   no -  Vendor-Specific (Optional)
D21                     : 0   no -  Vendor-Specific (Optional)
D22                     : 0   no -  Vendor-Specific (Optional)
D23                     : 0   no -  Vendor-Specific (Optional)
D24                     : 0   no -  Vendor-Specific (Optional)
D25                     : 0   no -  Vendor-Specific (Optional)
D26                     : 0   no -  Vendor-Specific (Optional)
D27                     : 0   no -  Vendor-Specific (Optional)
D28                     : 0   no -  Vendor-Specific (Optional)
D29                     : 0   no -  Vendor-Specific (Optional)
D30                     : 0   no -  Vendor-Specific (Optional)
D31                     : 0   no -  Vendor-Specific (Optional)
iExtension               : 0x00 (No String Descriptor)
Data (HexDump)           : 1D 24 06 0A 41 76 9E A2 04 DE E3 47 8B 2B F4 34   .$..Av.....G.+.4
                           1A FF 00 3B 0F 01 02 04 FF 03 00 00 00            ...;.........
        ------- Video Control Output Terminal Descriptor ------
bDescriptorSubtype       : 0x03 (Output Terminal)
bTerminalID              : 0x03 (3)
wTerminalType            : 0x0101 (TT_STREAMING)
bAssocTerminal           : 0x00 (Not associated with an Input Terminal)
bSourceID                : 0x02 (2)
Data (HexDump)           : 09 24 03 03 01 01 00 02 00                        .$.......
        ----------------- Endpoint Descriptor -----------------
bLength                  : 0x07 (7 bytes)
bDescriptorType          : 0x05 (Endpoint Descriptor)
bEndpointAddress         : 0x83 (Direction=IN EndpointID=3)
bmAttributes             : 0x03 (TransferType=Interrupt)
wMaxPacketSize           : 0x0010
Bits 15..13             : 0x00 (reserved, must be zero)
Bits 12..11             : 0x00 (0 additional transactions per microframe -> allows 1..1024 bytes per packet)
Bits 10..0              : 0x10 (16 bytes per packet)
bInterval                : 0x08 (128 microframes -> 16 ms)
Data (HexDump)           : 07 05 83 03 10 00 08                              .......
        --- Class-specific VC Interrupt Endpoint Descriptor ---
bLength                  : 0x05 (5 bytes)
bDescriptorType          : 0x25 (Video Control Endpoint)
bDescriptorSubtype       : 0x03 (Interrupt)
wMaxTransferSize         : 0x0010 (16 bytes)
Data (HexDump)           : 05 25 03 10 00                                    .%...
bInterfaceNumber         : 0x01 (Interface 1)
bInterfaceSubClass       : 0x02 (Video Streaming)
iInterface               : 0x06 (String Descriptor 6)
Language 0x0409         : "Video Streaming"
Data (HexDump)           : 09 04 01 00 01 0E 02 00 06                        .........
        ---- VC-Specific VS Video Input Header Descriptor -----
bLength                  : 0x0F (15 bytes)
bDescriptorType          : 0x24 (Video Streaming Interface)
bDescriptorSubtype       : 0x01 (Input Header)
bNumFormats              : 0x02
wTotalLength             : 0x0105 (261 bytes)
bEndpointAddress         : 0x81 (Direction=IN  EndpointID=1)
bmInfo                   : 0x00 (Dynamic Format Change not supported)
bTerminalLink            : 0x03 (Output Terminal ID 3)
bStillCaptureMethod      : 0x00 (No Still Capture)
nbTriggerSupport         : 0x00 (Hardware Triggering not supported)
bTriggerUsage            : 0x00 (Host will initiate still image capture)
bControlSize             : 0x01 (1 bytes each)
Video Payload Format 1   : 0x00
D0                      : 0   no -  Key Frame Rate
D1                      : 0   no -  P Frame Rate
D2                      : 0   no -  Compression Quality
D3                      : 0   no -  Compression Window Size
D4                      : 0   no -  Generate Key Frame
D5                      : 0   no -  Update Frame Segment
Video Payload Format 2   : 0x00
Data (HexDump)           : 0F 24 01 02 05 01 81 00 03 00 00 00 01 00 00      .$.............
        ------- VS Uncompressed Format Type Descriptor --------
bLength                  : 0x1B (27 bytes)
bDescriptorSubtype       : 0x04 (Uncompressed Format Type)
bFormatIndex             : 0x01 (1)
bNumFrameDescriptors     : 0x05 (5 Frame Descriptors)
guidFormat               : {32595559-0000-0010-8000-00AA00389B71} (YUY2)
bBitsPerPixel            : 0x10 (16 bits per pixel)
bDefaultFrameIndex       : 0x01 (Index 1)
bAspectRatioX            : 0x00
bAspectRatioY            : 0x00
bmInterlaceFlags         : 0x00
D0 IL stream or variable: 0 (no)
D1 Fields per frame     : 0 (2 fields)
D2 Field 1 first        : 0 (no)
D3 Reserved             : 0
D4..5 Field pattern     : 0 (Field 1 only)
D6..7 Display Mode      : 0 (Bob only)
bCopyProtect             : 0x00 (No restrictions)
Data (HexDump)           : 1B 24 04 01 05 59 55 59 32 00 00 10 00 80 00 00   .$...YUY2.......
                           AA 00 38 9B 71 10 01 00 00 00 00                  ..8.q......
        -------- VS Uncompressed Frame Type Descriptor --------
---> This is the Default (optimum) Frame index
bLength                  : 0x1E (30 bytes)
bDescriptorSubtype       : 0x05 (Uncompressed Frame Type)
bFrameIndex              : 0x01
bmCapabilities           : 0x00
wWidth                   : 0x0100 (256)
wHeight                  : 0x0158 (344)
dwMinBitRate             : 0x0280A000 (41984000 bps -> 5.248 MB/s)
dwMaxBitRate             : 0x0280A000 (41984000 bps -> 5.248 MB/s)
dwMaxVideoFrameBufferSize: 0x00033400 (209920 bytes)
dwDefaultFrameInterval   : 0x00061A80 (40.0000 ms -> 25.0000 fps)
bFrameIntervalType       : 0x01 (1 discrete frame interval supported)
adwFrameInterval[1]      : 0x00061A80 (40.0000 ms -> 25.0000 fps)
Data (HexDump)           : 1E 24 05 01 00 00 01 58 01 00 A0 80 02 00 A0 80   .$.....X........
                           02 00 34 03 00 80 1A 06 00 01 80 1A 06 00         ..4...........
bFrameIndex              : 0x03
wHeight                  : 0x00C4 (196)
Data (HexDump)           : 1E 24 05 03 00 00 01 C4 00 00 A0 80 02 00 A0 80   .$..............
bFrameIndex              : 0x04
wWidth                   : 0x1591 (5521)
wHeight                  : 0x0010 (16)
Data (HexDump)           : 1E 24 05 04 00 91 15 10 00 00 A0 80 02 00 A0 80   .$..............
bFrameIndex              : 0x08
wHeight                  : 0x0168 (360)
Data (HexDump)           : 1E 24 05 08 00 00 01 68 01 00 A0 80 02 00 A0 80   .$.....h........
bFrameIndex              : 0x09
wWidth                   : 0x01CF (463)
wHeight                  : 0x00DC (220)
Data (HexDump)           : 1E 24 05 09 00 CF 01 DC 00 00 A0 80 02 00 A0 80   .$..............
        ------- VS Color Matching Descriptor Descriptor -------
bLength                  : 0x06 (6 bytes)
bDescriptorSubtype       : 0x0D (Color Matching)
bColorPrimaries          : 0x01 (BT.709, sRGB)
bTransferCharacteristics : 0x01 (BT.709)
bMatrixCoefficients      : 0x04 (SMPTE 170M)
Data (HexDump)           : 06 24 0D 01 01 04                                 .$....
bFormatIndex             : 0x02 (2)
bNumFrameDescriptors     : 0x01 (1 Frame Descriptor)
guidFormat               : {3231564E-0000-0010-8000-00AA00389B71} (NV12)
bBitsPerPixel            : 0x0C (12 bits per pixel)
D3 Reserved             : 0
Data (HexDump)           : 1B 24 04 02 01 4E 56 31 32 00 00 10 00 80 00 00   .$...NV12.......
                           AA 00 38 9B 71 0C 01 00 00 00 00                  ..8.q......
bFrameIndex              : 0x02
wHeight                  : 0x00C0 (192)
Data (HexDump)           : 1E 24 05 02 00 00 01 C0 00 00 A0 80 02 00 A0 80   .$..............
bmAttributes             : 0x02 (TransferType=Bulk)
wMaxPacketSize           : 0x0200 (max 512 bytes)
bInterval                : 0x00 (never NAKs)
Data (HexDump)           : 07 05 81 02 00 02 00                              .......
    ----------------- Device Qualifier Descriptor -----------------
Error                    : ERROR_GEN_FAILURE  (*!*ERROR   USB 2.0 HighSpeed devices must provide a Device Qualifier Descriptor)
      -------------------- String Descriptors -------------------
             ------ String Descriptor 0 ------
bLength                  : 0x04 (4 bytes)
bDescriptorType          : 0x03 (String Descriptor)
Language ID[0]           : 0x0409 (English - United States)
Data (HexDump)           : 04 03 09 04                                       ....
             ------ String Descriptor 1 ------
Data (HexDump)           : 08 03 48 00 49 00 4B 00                           ..H.I.K.
             ------ String Descriptor 2 ------
bLength                  : 0x0E (14 bytes)
Data (HexDump)           : 0E 03 43 00 61 00 6D 00 65 00 72 00 61 00         ..C.a.m.e.r.a.
             ------ String Descriptor 3 ------
bLength                  : 0x14 (20 bytes)
Data (HexDump)           : 14 03 45 00 41 00 33 00 33 00 37 00 37 00 39 00   ..E.A.3.3.7.7.9.
                           32 00 39 00                                       2.9.
             ------ String Descriptor 4 ------
Data (HexDump)           : 12 03 43 00 6F 00 6E 00 66 00 69 00 67 00 20 00   ..C.o.n.f.i.g. .
                           31 00                                             1.
             ------ String Descriptor 5 ------
bLength                  : 0x16 (22 bytes)
Data (HexDump)           : 16 03 55 00 56 00 43 00 20 00 43 00 61 00 6D 00   ..U.V.C. .C.a.m.
                           65 00 72 00 61 00                                 e.r.a.
             ------ String Descriptor 6 ------
bLength                  : 0x20 (32 bytes)
Data (HexDump)           : 20 03 56 00 69 00 64 00 65 00 6F 00 20 00 53 00    .V.i.d.e.o. .S.
                           74 00 72 00 65 00 61 00 6D 00 69 00 6E 00 67 00   t.r.e.a.m.i.n.g.
GMT+8, 2026-11-8 17:43 , Processed in 0.074450 second(s), 41 queries .
