- 打卡等级:以坛为家I
- 打卡总天数:261
- 最近打卡:2025-12-11 08:57:38
- 积分
- 21129
发表于 2023-4-28 13:03:20
显示全部楼层
为准确的采样到每个BIT, INTEL 好像是16倍的采样速度,我们为了加速串口速度/[如40M/4 = 10M bps, 0误差],
减少波特率计算误差,我当时建议4倍采样就可以了 !
这样广泛的宽范围波特率误差也小了,/16那是历史的局限,这个【理论+实践】 是有充分的实践的
这就是我们的实践
//本示例在Keil开发环境下请选择Intel的8058芯片型号进行编译
//若无特别说明,工作频率一般为11.0592MHz
#include "reg51.h"
//define baudrate const
//BAUD = 65536 - FOSC/3/BAUDRATE/M (1T:M=1; 12T:M=12)
//NOTE: (FOSC/3/BAUDRATE) must be greater then 98, (RECOMMEND GREATER THEN 110)
//#define BAUD 0xF400 // 1200bps @ 11.0592MHz
//#define BAUD 0xFA00 // 2400bps @ 11.0592MHz
//#define BAUD 0xFD00 // 4800bps @ 11.0592MHz
//#define BAUD 0xFE80 // 9600bps @ 11.0592MHz
//#define BAUD 0xFF40 //19200bps @ 11.0592MHz
#define BAUD 0xFFA0 //38400bps @ 11.0592MHz
//#define BAUD 0xEC00 // 1200bps @ 18.432MHz
//#define BAUD 0xF600 // 2400bps @ 18.432MHz
//#define BAUD 0xFB00 // 4800bps @ 18.432MHz
//#define BAUD 0xFD80 // 9600bps @ 18.432MHz
//#define BAUD 0xFEC0 //19200bps @ 18.432MHz
//#define BAUD 0xFF60 //38400bps @ 18.432MHz
//#define BAUD 0xE800 // 1200bps @ 22.1184MHz
//#define BAUD 0xF400 // 2400bps @ 22.1184MHz
//#define BAUD 0xFA00 // 4800bps @ 22.1184MHz
//#define BAUD 0xFD00 // 9600bps @ 22.1184MHz
//#define BAUD 0xFE80 //19200bps @ 22.1184MHz
//#define BAUD 0xFF40 //38400bps @ 22.1184MHz
//#define BAUD 0xFF80 //57600bps @ 22.1184MHz
sfr AUXR = 0x8E;
sbit RXB = P3^0; //define UART TX/RX port
sbit TXB = P3^1;
typedef bit BOOL;
typedef unsigned char BYTE;
typedef unsigned int WORD;
BYTE TBUF,RBUF;
BYTE TDAT,RDAT;
BYTE TCNT,RCNT;
BYTE TBIT,RBIT;
BOOL TING,RING;
BOOL TEND,REND;
void UART_INIT();
BYTE t, r;
BYTE buf[16];
TMOD = 0x00; //timer0 in 16-bit auto reload mode
AUXR = 0x80; //timer0 working at 1T mode
TL0 = BAUD;
TH0 = BAUD>>8; //initial timer0 and set reload value
TR0 = 1; //tiemr0 start running
ET0 = 1; //enable timer0 interrupt
PT0 = 1; //improve timer0 interrupt priority
EA = 1; //open global interrupt switch
UART_INIT();
{ //user's function
if (REND)
REND = 0;
buf[r++ & 0x0f] = RBUF;
if (TEND)
if (t != r)
TEND = 0;
TBUF = buf[t++ & 0x0f];
TING = 1;
//Timer interrupt routine for UART
void tm0() interrupt 1
if (RING)
if (--RCNT == 0)
RCNT = 3; //reset send baudrate counter
if (--RBIT == 0)
RBUF = RDAT; //save the data to RBUF
RING = 0; //stop receive
REND = 1; //set receive completed flag
RDAT >>= 1;
if (RXB) RDAT |= 0x80; //shift RX data to RX buffer
else if (!RXB)
RING = 1; //set start receive flag
RCNT = 4; //initial receive baudrate counter
RBIT = 9; //initial receive bit number (8 data bits + 1 stop bit)
if (--TCNT == 0)
TCNT = 3; //reset send baudrate counter
if (TING) //judge whether sending
if (TBIT == 0)
TXB = 0; //send start bit
TDAT = TBUF; //load data from TBUF to TDAT
TBIT = 9; //initial send bit number (8 data bits + 1 stop bit)
TDAT >>= 1; //shift data to CY
if (--TBIT == 0)
TXB = 1;
TING = 0; //stop send
TEND = 1; //set send completed flag
TXB = CY; //write CY to TX port
//initial UART module variable
void UART_INIT()
TING = 0;
RING = 0;
TEND = 1;
REND = 0;
TCNT = 0;
RCNT = 0;
