楼主: 王锦平
玄学的eeprom保存
发表于 2025-3-3 13:24:16 | 显示全部楼层
学习一下
 楼主| 发表于 2025-3-3 18:14:32 | 显示全部楼层
[quote][size=2][url=forum.php?mod=redirect&goto=findpost&pid=149140&ptid=15405][color=#999999]ercircle 发表于 2025-3-3 12:39[/color][/url][/size] 这里写之前擦的地址正确吗?建议贴完整可复现的工程上来方便大家帮你分析 [/quote]
以下是EEPROM的宏定义
#define CMD_IDLE    0               //空闲模式
#define CMD_READ    1               //IAP字节读命令
#define CMD_PROGRAM 2               //IAP字节编程命令
#define CMD_ERASE   3               //IAP扇区擦除命令
#define ENABLE_IAP 0x80             //if SYSCLK<30MHz
#define IAP_TPS_CONSTANT ((FOSC/1000000)+1+1)
//测试地址
#define IAP_ADDRESS0 0x0000 //第一扇区地址
#define IAP_ADDRESS1 0x0200	//第二扇区地址
#define IAP_ADDRESS2 0x0400	//第三扇区地址
#define IAP_ADDRESS3 0x0800	//第四扇区地址
#define IAP_ADDRESS4 0x0A00	//第五扇区地址
#define IAP_ADDRESS5 0x0C00	//第六扇区地址
#define EEPROM_DEVID_ADDR IAP_ADDRESS0
#define EEPROM_DEVID_START_ADDR (EEPROM_DEVID_ADDR + 0)
#define EEPROM_DEVID_END_ADDR (EEPROM_DEVID_ADDR + 4)
#define EEPROM_QRCODE_FLAG_ADDR (EEPROM_DEVID_ADDR + 5)
#define EEPROM_NAME_MAX_LEN (16U)
#define EEPROM_NAME_START_ADDR IAP_ADDRESS1
#define EEPROM_NAME1_CNT_ADDR (EEPROM_NAME_START_ADDR + 0)
#define EEPROM_NAME2_CNT_ADDR (EEPROM_NAME_START_ADDR + 1)
#define EEPROM_NAME3_CNT_ADDR (EEPROM_NAME_START_ADDR + 2)
#define EEPROM_NAME4_CNT_ADDR (EEPROM_NAME_START_ADDR + 3)
#define EEPROM_NAME1STR_ADDR (EEPROM_NAME_START_ADDR + 5 + (EEPROM_NAME_MAX_LEN * 0))
#define EEPROM_NAME2STR_ADDR (EEPROM_NAME_START_ADDR + 5 + (EEPROM_NAME_MAX_LEN * 1))
#define EEPROM_NAME3STR_ADDR (EEPROM_NAME_START_ADDR + 5 + (EEPROM_NAME_MAX_LEN * 2))
#define EEPROM_NAME4STR_ADDR (EEPROM_NAME_START_ADDR + 5 + (EEPROM_NAME_MAX_LEN * 3))
#define EEPROM_NAME_END_ADDR (EEPROM_NAME4STR_ADDR + EEPROM_NAME_MAX_LEN)
写之前擦除错误的扇区导致的?  详情 回复 发表于 2025-3-3 18:46
发表于 2025-3-3 18:46:48 | 显示全部楼层
王*** 发表于 2025-3-3 18:14
以下是EEPROM的宏定义
#define CMD_READ    1          ...
写之前擦除错误的扇区导致的?
 楼主| 发表于 2025-3-3 18:52:03 | 显示全部楼层
[quote][size=2][url=forum.php?mod=redirect&goto=findpost&pid=149242&ptid=15405][color=#999999]ercircle 发表于 2025-3-3 18:46[/color][/url][/size] 写之前擦除错误的扇区导致的?[/quote]
大佬太细了,膜拜
这么一提,发现确实是忘记修改要被擦除的扇区了,导致写不了却又没有返回错误值。。。
我一直都以为我擦除的扇区是正确的。。。
打工人
发表于 2025-5-19 16:48:04 | 显示全部楼层
国芯人*** 发表于 2025-3-3 11:18
根据您的描述,EEPROM读写的ASCII码数据不匹配,可能涉及以下几个问题:首先,检查EEPROM的起始地址和结束 ...
eeprom是片内的吧,和硬件连接是不是没关系了
打工人
GMT+8, 2026-11-7 13:16 , Processed in 0.072643 second(s), 75 queries .
