查看: 1073|回复: 5
8H8K64U的RTC时钟调用不触发
  • 打卡总天数:1
  • 最近打卡:2025-01-20 15:42:40
发表于 2025-2-21 14:27:26 | 显示全部楼层 |阅读模式
使用官方的范例程序烧录都不触发,串口1没有任何输出。我用的是8H8K64U GD,D版本的,应该是有RTC时钟的。
而且本来串口能正常输出的,现在调用RTC后就没有任何输出了
#include "STC8H.H"
#include "stdio.h"
#include "string.h"
#define MAIN_Fosc        11095200
#define BRT        115200
#define        TM        (65536-(MAIN_Fosc/BRT/4))
#define MAX        64
bit B1S_Flag;
bit busy;
bit busy2;
bit busy3;
unsigned char wptr;
unsigned char rptr;
unsigned char wptr2;
unsigned char rptr2;
unsigned char wptr3;
unsigned char rptr3;
xdata unsigned char buffer[MAX];
xdata unsigned char buffer2[MAX];
xdata unsigned char buffer3[MAX];
void Delay1000ms(void)        //@11.0592MHz
        unsigned char data i, j, k;
        i = 43;
        j = 6;
        k = 203;
        do
                do
                        while (--k);
                } while (--j);
        } while (--i);
void UartIsr() interrupt 4
        if(TI)        //发送
                TI=0;
                busy=0;
        if(RI)
                RI=0;
                buffer[wptr++]=SBUF;
                if(wptr>=(MAX))        wptr=0;
void UartInit()
  SCON=0x50;
  TMOD=0x00;
  TL1=BRT;
  TH1=BRT>>8;
  TR1=1;
  AUXR=0x15;
  wptr=0x00;
  rptr=0x00;
  S2CON=0x10;
  TL2=BRT;
  TH2=BRT>>8;
  wptr2=0x00;
  rptr2=0x00;
        S3CON=0x10;
        TL3=BRT;
        TH3=BRT>>8;
        //AUXR=0x14;
        wptr3=0x00;
        rptr3=0x00;
  busy=0;
        busy2=0;
        busy3=0;
        if(TI)        //发送
                TI=0;
                busy=0;
        if(RI)
                RI=0;
void RTC_config(void);
void UartInit(void)
        SCON=(SCON&0x3f)|0x40;
        TL2=TM;
        TH2=TM>>8;
        AUXR|=0x15;
void UartSend(char dat)
        while(busy);
        busy=1;
        SBUF=dat;
        SBUF=dat;
        while(TI==0);
        TI=0;
void UartSendStr(char *p)
        int i=0;
        int l=strlen(p);
        //UartSendStr("\n--------rsend--------\n");
        //UartSendStr(p);
        for(i=0;i<=(l-1);i++)
                UartSend(p);
char putchar(char c)
        UartPutc(c);
        return c;
void RTC_Isr()        interrupt 13
        char store;
        store=P_SW2;
        P_SW2|=0x80;
        if(RTCIF&0x08)
                RTCIF&=~0x08;
                B1S_Flag=1;
        P_SW2=store;
        P0M1=0;        P0M0=0;
        P1M1=0;        P1M0=0;
        P2M1=0;        P2M0=0;
        P3M1=0;        P3M0=0;
        P4M1=0;        P4M0=0;
        P5M1=0;        P5M0=0;
        UartInit();
        RTC_config();
        EA=1;
        Delay1000ms();
        Delay1000ms();
        Delay1000ms();
        UartSendStr("1RTC Test Programme!\r\n");
        printf("2RTC Test Programme!\r\n");
                char yearStr[5];  // 足够存储两位年份
                yearStr[0] = (YEAR / 10) + '0';  // 十位
                yearStr[1] = (YEAR % 10) + '0';  // 个位
                yearStr[2] = '\0';
                if(B1S_Flag)
                        B1S_Flag=0;
                        P_SW2|=0x80;
                        UartSendStr(yearStr);
                        printf("Year=20%bd",YEAR);
                        printf("\r\n");
                Delay1000ms();
        P_SW2|=0x80;
        while(!(IRC32KCR&0x01));
        RTCCFG|=0x02;
        INIYEAR=25;
        INIMONTH=12;
        INIDAY=31;
        INIHOUR=23;
        INIMIN=59;
        INISEC=50;
        INISSEC=0;
        RTCCFG|=0x01;
        RTCIF=0;
        RTCIEN=0x08;
        RTCCR=0x01;
        P_SW2&=~0x80;
  • 打卡总天数:727
  • 最近打卡:2026-06-26 17:48:25
发表于 2025-2-21 14:50:02 | 显示全部楼层
RTC中断是否正常跳转
打开的中断必须要有中断函数
借用中断13必须保证正常跳转
打开RTC必须使用外部32768Hz晶振,晶振IO必须设置为高阻,并在初始化打开晶振后等待时钟稳定(内部32K仅供测试,看秒钟在走表示RTC正常工作,没有准确度,不建议实际运行使用)
  • 打卡总天数:697
  • 最近打卡:2026-07-04 21:56:03
发表于 2025-2-21 14:52:02 | 显示全部楼层
几个疑问,,
1.为啥你选择24M下载程序,而你的宏定义MAIN_Fosc 11095200 ?
2.看你这里中断是借用13号中断,但是你没有给出你的isr.asm里面的代码,是否正确使用了13号中断?
3.看起来你想用内部的低速IRC作为RTC的时钟,但是代码里好像没有看到你开启低速IRC时钟的代码...
  • 打卡总天数:788
  • 最近打卡:2026-07-05 13:03:19
发表于 2025-2-21 15:30:00 | 显示全部楼层
RTC和串口没有任何关系,串口卡死是串口代码的问题,即使RTC不启动也不会影响串口操作。
  • 打卡总天数:939
  • 最近打卡:2026-07-04 02:00:58
发表于 2025-2-21 17:11:45 | 显示全部楼层
少了这个。
;isr.asm
        CSEG        AT        011BH                ;35号 触摸按键 中断入口
        LJMP        006BH                        ;跳转到中断号13的向量
        CSEG    AT  0123H           ;36号 RTC_VECTOR
        END
  • 打卡总天数:816
  • 最近打卡:2026-07-05 00:48:06
发表于 2025-3-11 00:15:18 来自手机 | 显示全部楼层
好像没有外部晶振无法工作吧?我用开天斧好像没有成功…看手册得上外部晶振…
GMT+8, 2026-7-5 17:01 , Processed in 0.071542 second(s), 72 queries .
