查看: 905|回复: 4
8g1k08芯片的外部中断0可以触发,但是1不行是为什么
发表于 2025-2-19 11:41:52 | 显示全部楼层 |阅读模式
#include "STC8G.h"
#define uint  unsigned int
#define uchar unsigned char
#define beep P23
#define dula P26
#define wela P27
uint    num , c;
uchar code table[]={
        0x3f,0x06,0x5b,0x4f,
        0x66,0x6d,0x7d,0x07,
        0x7f,0x6f,0x77,0x7c,
        0x39,0x5e,0x79,0x71};
                void DelayMs(uint c);
                void Display(uint shu);
                P0M0 = 0xff; P0M1 = 0x00;
    P1M0 = 0xff; P1M1 = 0x00;
    P2M0 = 0xff; P2M1 = 0x00;
    P3M0 = 0x50; P3M1 = 0x50;
    P4M0 = 0xff; P4M1 = 0x00;
    P5M0 = 0x10; P5M1 = 0x10;
    P6M0 = 0xff; P6M1 = 0x00;
    P7M0 = 0xff; P7M1 = 0x00;
                IE1  = 0;
    IE0  = 0;
    EX1 = 1;    //INT1 Enable
    EX0 = 1;    //INT0 Enable
                ET1        =1;
    IT0 = 1;
//  IT0 = 0;
//         IT1 = 0;
                IT1 =1;
                EA=1;
        P37=0;
        P36=0;
        P35=0;
        num==0;
                Display(num);
void INt0_int (void)       interrupt 0
                    if(P32==0)
                        Display(num);
                        num++;
                        P5M0=0x20;
                        while(!P32);
                        Display(num);
                        P5M0=0x00;
void INt1_int (void)        interrupt  2
        if(P54==0)
                        num--;
                        P5M0=0x20;
                                while(!P54);
                        Display(num);
                                P5M0=0x00;
                P37=0;
                P1=table[shu/100];//ÏÔʾ0
                DelayMs(5);
                P37=1;
                P36=0;
                P1=table[shu/10%10];//ÏÔʾ0
                DelayMs(5);
                P36=1;
                P35=0;
                P1=table[shu%10];//ÏÔʾ0
                DelayMs(5);
                P35=1;
        uint a,b;
        for(a=c;a>0;a--)
                for(b=115;b>0;b--);
  • 打卡总天数:684
  • 最近打卡:2026-03-06 00:36:37
发表于 2025-2-19 11:48:35 | 显示全部楼层
建议做个最简单的专项测试例程,独立测试一下功能,
发表于 2025-2-19 11:53:42 | 显示全部楼层
好,我试试
  • 打卡总天数:282
  • 最近打卡:2026-02-26 14:21:32
发表于 2025-2-19 13:10:04 | 显示全部楼层
发表于 2025-2-24 11:06:11 | 显示全部楼层
已解决,谢谢了
GMT+8, 2026-3-6 03:37 , Processed in 0.110521 second(s), 62 queries .
