查看: 876|回复: 2
C51 中断内可以调用函数指针么
  • 打卡总天数:1
  • 最近打卡:2025-01-15 18:21:58
发表于 2025-1-13 15:08:10 | 显示全部楼层 |阅读模式
困惑点:由于51单片机的局部变量实际占用的内存空间是共享的,不知道函数指针这样的调用关系,
       编译器能否自动识别正确,如果不能就会导致局部变量数据错乱。
void (*uart2_rx_int_callback)(void) = NULL;
void (*uart2_tx_int_callback)(void) = NULL;
void UART2_ISR_Handler (void) interrupt UART2_VECTOR
    if(RI2)
        CLR_RI2();
        if (uart2_rx_int_callback) {
            uart2_rx_int_callback();
    if(TI2)
        CLR_TI2();
        if (uart2_tx_int_callback) {
            uart2_tx_int_callback();
u8 mw_prtc_cal_sum(u8 *p_buf,u8 l)
    u16 sum = 0;
    u8 i;
    for (i = 0;i < l;i ++) {
        sum += p_buf;
    i = sum & 0x00ff;
    return i;
void mw_uart_rx_int_callback(void)
    static u8 i = 0;
    static bit re_head = 0;
    static bit re_length  = 0;
    static u8 j;
    static u8 sum = 0;
    if (!MW_COM.B_RX_busy) {
        mw_rx_buf[i++] = MW_UART_SBUF;
        if (!re_head) {
            if (i > MW_PRTC_POSI_HEAD_END) {
                if ((mw_rx_buf[i - 2] == MW_PRTC_HEAD1) && (mw_rx_buf[i - 1] == MW_PRTC_HEAD2_F_SLAVE)) {
                    re_head = 1;
                    mw_rx_buf[MW_PRTC_POSI_HEAD] = MW_PRTC_HEAD1;
                    mw_rx_buf[MW_PRTC_POSI_HEAD_END] = MW_PRTC_HEAD2_F_SLAVE;
                    i = MW_PRTC_POSI_LENGTH;
                } else {
                    i = 0;
        } else {
            if (!re_length) {
                if (i > MW_PRTC_POSI_LENGTH_END) {
                    re_length = 1;
                    MW_COM.RX_Cnt = *(u16*)&mw_rx_buf[MW_PRTC_POSI_LENGTH] + MW_PRTC_BEFOR_FUNC_LENGTH;
            } else {
                if (i >= MW_COM.RX_Cnt) {
                    sum = mw_prtc_cal_sum(mw_rx_buf, MW_COM.RX_Cnt);
                    PRINTF_INFO_ARRA("rb",mw_rx_buf,j,MW_COM.RX_Cnt);
                    PRINTF_INFO("su=%02bx\r\n",sum);
                    if (sum == mw_rx_buf[i - 1]) {
                        MW_COM.B_RX_busy = 1;
                        i = 0;
                        re_head = 0;
                        re_length = 0;
        if (i >= MW_RX_PROTOCOL_LENGTH_MAX) {
            i = 0;
            re_head = 0;
            re_length = 0;
            MW_COM.B_RX_busy = 0;
串口初始化时会给函数指针初始化
    uart2_tx_int_callback = mw_uart_tx_int_callback;
    uart2_rx_int_callback = mw_uart_rx_int_callback;
  • 打卡总天数:644
  • 最近打卡:2025-12-15 07:35:15
发表于 2025-1-14 06:33:37 | 显示全部楼层
  • 打卡总天数:1
发表于 2025-1-15 18:21:37 | 显示全部楼层
Debu*** 发表于 2025-1-14 06:33
https://www.stcaimcu.com/forum.php?mod=viewthread&tid=13643
好的多谢!
GMT+8, 2025-12-16 02:34 , Processed in 0.106399 second(s), 55 queries .
