楼主: 一点痕迹
AI8051U学习打卡
  • 打卡总天数:8
  • 最近打卡:2025-11-24 18:32:18
发表于 2024-12-20 19:27:02 | 显示全部楼层
第七课 课后练习作业
#include "ai8051u.h"
#include <intrins.h>
#include "stc32_stc8_usb.h"
char *USER_DEVICEDESC = NULL;
unsigned char LED = 0;		//LED变量
unsigned char GD1 = 0;      //功德计数
//设置定时器2为1秒溢出
void Timer2_Init(void)		//1秒@24.000MHz
	TM2PS = 0x1E;			//设置定时器时钟预分频 ( 注意:并非所有系列都有此寄存器,详情请查看数据手册 )
	AUXR &= 0xFB;			//定时器时钟12T模式
	T2L = 0xFC;				//设置定时初始值
	T2H = 0x03;				//设置定时初始值
	AUXR |= 0x10;			//定时器2开始计时
	IE2 |= 0x04;			//使能定时器2中断
//设置定时器3为2秒溢出
void Timer3_Init(void)		//2秒@24.000MHz
	TM3PS = 0x3D;			//设置定时器时钟预分频 ( 注意:并非所有系列都有此寄存器,详情请查看数据手册 )
	T4T3M &= 0xFD;			//定时器时钟12T模式
	T3L = 0xFC;				//设置定时初始值
	T3H = 0x03;				//设置定时初始值
	T4T3M |= 0x08;			//定时器3开始计时
	IE2 |= 0x20;			//使能定时器3中断
	WTST = 0;  //设置程序指令延时参数,赋值为0可将CPU执行指令的速度设置为最快
    EAXFR = 1; //扩展寄存器(XFR)访问使能
    CKCON = 0; //提高访问XRAM速度
	 P_SW2 |= 0x80;
    P0M1 = 0x00;   P0M0 = 0x00;
    P1M1 = 0x00;   P1M0 = 0x00;
    P2M1 = 0x00;   P2M0 = 0x00;
    P3M1 = 0x00;   P3M0 = 0x00;
    P4M1 = 0x00;   P4M0 = 0x00;
    P5M1 = 0x00;   P5M0 = 0x00;
    P6M1 = 0x00;   P6M0 = 0x00;
    P7M1 = 0x00;   P7M0 = 0x00;
    usb_init();                                    	 	//USB CDC 接口配置
	P40 = 0;    //LED 总开关
	    while (DeviceState != DEVSTATE_CONFIGURED);     //等待USB完成配置
		 if ( P32 == 0 )
            USB_SendData(UsbOutBuffer,OutNumber);   //发送数据缓冲区,长度(接收数据原样返回, 用于测试)
			printf("功德+1: %u 次\r\n ",(unsigned int)(GD1));
			GD1 ++;
            usb_OUT_done();
			LED = 0;						//点亮LED
			P00 = LED;
			P01 = LED;
			P02 = LED;
			P03 = LED;
			P04 = LED;
			P05 = LED;
			P06 = LED;
			P07 = LED;
		    Timer2_Init(); 				//定时器2初始化
			while( P32 == 0 )
		if ( P33 == 0 )
			printf("功德+2: %u 次\r\n ",(unsigned int)(GD1));
			GD1 += 2;
            usb_OUT_done();
			LED = 0;						//点亮LED
			P00 = LED;
			P01 = LED;
			P02 = LED;
			P03 = LED;
			P04 = LED;
			P05 = LED;
			P06 = LED;
			P07 = LED;
			Timer3_Init();               //初始化定时器3
			while( P33 == 0 )
//定时器2中断函数 1秒关闭LED
void Timer2_Isr(void) interrupt 12
	LED = 1;
	P00 = LED;
	P01 = LED;
	P02 = LED;
	P03 = LED;
	P04 = LED;
	P05 = LED;
	P06 = LED;
	P07 = LED;
	AUXR &= ~0x10;    //暂停定时器2
//定时器3中断函数 2秒关闭LED
void Timer3_Isr(void) interrupt 19
	LED = 1;
	P00 = LED;
	P01 = LED;
	P02 = LED;
	P03 = LED;
	P04 = LED;
	P05 = LED;
	P06 = LED;
	P07 = LED;
	T4T3M &= ~0x08;	//暂停定时器3
  • 打卡总天数:8
发表于 2024-12-20 19:32:37 | 显示全部楼层
[quote][size=2][url=forum.php?mod=redirect&goto=findpost&pid=132676&ptid=12568][color=#999999]一点痕迹 发表于 2024-12-20 19:27[/color][/url][/size] 第七课 课后练习作业 #include "ai8051u.h" #include <intrins.h> [/quote]
bug修改
                GD1 ++;
         usb_OUT_done();
改为 解决串口输出延迟一次按键计数的bug
		GD1 ++;
        usb_OUT_done();
GMT+8, 2026-4-3 04:28 , Processed in 0.110768 second(s), 47 queries .
