AI8051U实验箱使用LQFP-48封装的AI8051U芯片
其引脚排布如下:
引脚排布(点击展开)
单片机系列 AI8051U 系列
封装类型 LQFP48
1 P5.3/TxD4_2/PWM8_4/QSPIIO3_2
2 P1.5/ADC5/MOSI/SCL_2/PWM3N/PWM7_2/QSPIIO0/I2SSD_2
3 P1.6/ADC6/RxD_3/MISO/PWM4P/QSPIIO1/I2SMCLK_2/I2SMCLK_4
4 P1.7/ADC7/TxD_3/SCLK/PWM4N/PWM8_2/QSPICLK/I2SCK_2
5 P4.7/RST/MCLKO/ADC_ETR/QSPINCS_3
6 P3.0/INT4/RxD/D-
7 P4.3/RxD_4/TxD2_2/SCLK_3/CCP1_2/QSPICLK_2/I2SCK_4
8 P3.1/TxD/D+
9 P3.2/INT0/SCLK_4/SCL_4/PWM_ETI1/PWM_ETI2/I2SCK
10 P3.3/INT1/MISO_4/SDA_4/I2SMCLK
11 P3.4/T0/T1CLKO/MOSI_4/I2SSD
12 P3.5/T1/T0CLKO/SS_4/PWMFLT/I2SWS
13 P3.6/INT2/WR_2/RxD_2
14 P3.7/INT3/RD_2/TxD_2
15 P5.6/XTALO/MCLKO_2
16 P5.7/XTALI
17 ADC_Vref-/ADC_AGnd/Gnd
18 P4.0/SS_3/ADCETR_2/QSPINCS_2/I2SWS_4
19 P2.0/A8/T11/CCP0_3/PWM1P_3/ADCETR_3/I2SWS_3
20 P2.1/A9/T11CLKO/CCP1_3/PWM1N_3/PWM5_3/I2SSD_3
21 P2.2/A10/CCP2_3/PWM2P_3/I2SMCLK_3
22 P2.3/A11/SDA/ECI_3/PWM2N_3/PWM6_3/PWM_ETI1_3/PWM_ETI2_3/I2SCK_3
23 P2.4/A12/SS_2/SCL/PWM3P_3
24 P5.0/RxD3_2/PWM5_4
25 P5.1/TxD3_2/PWM6_4
26 P2.5/A13/MOSI_2/PWM3N_3/PWM7_3/ QSPIIO0_3
27 P2.6/A14/MISO_2/PWM4P_3/QSPIIO1_3
28 P2.7/A15/SCLK_2/PWM4N_3/PWM8_3/QSPICLK_3
29 UCAP
30 P4.5/ALE/CMPO/QSPIIO3_3
31 P4.1/CMPO_2/ECI_2/MOSI_3/PWMETI1_2/PWMETI2_2/QSPIIO0_2/I2SSD_4
32 P4.6/CMP+/QSPIIO2_3
33 P0.7/AD7/T4CLKO/CMP+_2/PWM4N_2/PWM8/PWMFLT_3
34 P0.6/ADC14/AD6/T4/CMP+_3/PWM4P_2/PWMFLT_2
35 P0.5/ADC13/AD5/T3CLKO/CMP-/PWM3N_2/PWM7
36 P0.4/ADC12/AD4/T3/PWM3P_2
37 P0.3/ADC11/AD3/TxD4/PWM2N_2/PWM6
38 P0.2/ADC10/AD2/RxD4/PWM2P_2
39 P0.1/ADC9/AD1/TxD3/PWM1N_2/PWM5
40 P0.0/ADC8/AD0/RxD3/PWM1P_2
41 Vcc/ADC_AVcc/ADC_VRef+
42 P4.2/WR/RxD2_2/MISO_3/CCP0_2/QSPIIO1_2
43 P1.0/ADC0/T2/PWM1P
44 P1.1/ADC1/T2CLKO/CCP2/PWM1N/PWM5_2
45 P1.2/ADC2/RxD2/ECI/PWM2P/PWMETI1_4/PWMETI2_4/QSPIIO3
46 P1.3/ADC3/TxD2/CCP0/PWM2N/PWM6_2/QSPIIO2
47 P1.4/ADC4/SS/SDA_2/CCP1/PWM3P/QSPINCS/I2SWS_2
48 P5.2/RxD4_2/PWM7_4/QSPIIO2_2
实验箱引脚分配表
| 引脚序号 |
引脚名称 |
功能 |
| 40 |
P0.0/ADC8/AD0/RxD3/PWM1P_2 |
扩展RAM/流水灯/矩阵按键/示波器增益控制 |
| 39 |
P0.1/ADC9/AD1/TxD3/PWM1N_2/PWM5 |
| 38 |
P0.2/ADC10/AD2/RxD4/PWM2P_2 |
| 37 |
P0.3/ADC11/AD3/TxD4/PWM2N_2/PWM6 |
扩展RAM/流水灯/矩阵按键 |
| 36 |
P0.4/ADC12/AD4/T3/PWM3P_2 |
扩展RAM/流水灯/TFT彩屏 |
| 35 |
P0.5/ADC13/AD5/T3CLKO/CMP-/PWM3N_2/PWM7 |
扩展RAM/流水灯/TFT彩屏 |
| 34 |
P0.6/ADC14/AD6/T4/CMP+_3/PWM4P_2/PWMFLT_2 |
扩展RAM/流水灯/矩阵按键 |
| 33 |
P0.7/AD7/T4CLKO/CMP+_2/PWM4N_2/PWM8/PWMFLT_3 |
扩展RAM/流水灯/矩阵按键/方波输出 |
| 43 |
P1.0/ADC0/T2/PWM1P |
ADC按键 |
| 44 |
P1.1/ADC1/T2CLKO/CCP2/PWM1N/PWM5_2 |
OLED插座/示波器偏置控制 |
| 45 |
P1.2/ADC2/RxD2/ECI/PWM2P/PWMETI1_4/PWMETI2_4/QSPIIO3 |
话筒输入 |
| 46 |
P1.3/ADC3/TxD2/CCP0/PWM2N/PWM6_2/QSPIIO2 |
NTC测温/示波器输入 |
| 47 |
P1.4/ADC4/SS/SDA_2/CCP1/PWM3P/QSPINCS/I2SWS_2 |
TFT彩屏/I2S音频 |
| 2 |
P1.5/ADC5/MOSI/SCL_2/PWM3N/PWM7_2/QSPIIO0/I2SSD_2 |
TFT彩屏/I2S音频 |
| 3 |
P1.6/ADC6/RxD_3/MISO/PWM4P/QSPIIO1/I2SMCLK_2/I2SMCLK_4 |
I2S音频 |
| 4 |
P1.7/ADC7/TxD_3/SCLK/PWM4N/PWM8_2/QSPICLK/I2SCK_2 |
I2S音频 |
| 19 |
P2.0/A8/T11/CCP0_3/PWM1P_3/ADCETR_3/I2SWS_3 |
扩展RAM/12864显示屏/TFT彩屏 |
| 20 |
P2.1/A9/T11CLKO/CCP1_3/PWM1N_3/PWM5_3/I2SSD_3 |
| 21 |
P2.2/A10/CCP2_3/PWM2P_3/I2SMCLK_3 |
| 22 |
P2.3/A11/SDA/ECI_3/PWM2N_3/PWM6_3/PWM_ETI1_3/PWM_ETI2_3/I2SCK_3 |
扩展RAM/12864显示屏/TFT彩屏/正弦波输出 |
| 23 |
P2.4/A12/SS_2/SCL/PWM3P_3 |
扩展RAM/12864显示屏/TFT彩屏/microSD卡 |
| 26 |
P2.5/A13/MOSI_2/PWM3N_3/PWM7_3/QSPIIO0_3 |
| 27 |
P2.6/A14/MISO_2/PWM4P_3/QSPIIO1_3 |
| 28 |
P2.7/A15/SCLK_2/PWM4N_3/PWM8_3/QSPICLK_3 |
红外发射/12864显示屏/TFT彩屏/microSD卡 |
| 6 |
P3.0/INT4/RxD/D- |
USB通讯口/Link1D调试口/ISP串口 |
| 8 |
P3.1/TxD/D+ |
| 9 |
P3.2/INT0/SCLK_4/SCL_4/PWM_ETI1/PWM_ETI2/I2SCK |
独立按键/数码管/EEPROM/TFT彩屏/OLED插座 |
| 10 |
P3.3/INT1/MISO_4/SDA_4/I2SMCLK |
独立按键/单线温度传感器/EEPROM/TFT彩屏/OLED插座 |
| 11 |
P3.4/T0/T1CLKO/MOSI_4/I2SSD |
独立按键/数码管/TFT彩屏 |
| 12 |
P3.5/T1/T0CLKO/SS_4/PWMFLT/I2SWS |
独立按键/数码管/红外接收/OLED插座 |
| 13 |
P3.6/INT2/WR_2/RxD_2 |
扩展RAM/12864显示屏/TFT彩屏/UART串口 |
| 14 |
P3.7/INT3/RD_2/TxD_2 |
| 18 |
P4.0/SS_3/ADCETR_2/QSPINCS_2/I2SWS_4 |
Flash存储器/流水灯 |
| 31 |
P4.1/CMPO_2/ECI_2/MOSI_3/PWMETI1_2/PWMETI2_2/QSPIIO0_2/I2SSD_4 |
扩展RAM/Flash存储器 |
| 42 |
P4.2/WR/RxD2_2/MISO_3/CCP0_2/QSPIIO1_2 |
UART串口/RS-485串口/Flash存储器 |
| 7 |
P4.3/RxD_4/TxD2_2/SCLK_3/CCP1_2/QSPICLK_2/I2SCK_4 |
| 30 |
P4.5/ALE/CMPO/QSPIIO3_3 |
| 32 |
P4.6/CMP+/QSPIIO2_3 |
掉电检测比较器 |
| 5 |
P4.7/RST/MCLKO/ADC_ETR/QSPINCS_3 |
复位按钮/12864显示屏/TFT彩屏/OLED插座 |
| 24 |
P5.0/RxD3_2/PWM5_4 |
无源蜂鸣器/I2S音频 |
| 25 |
P5.1/TxD3_2/PWM6_4 |
NTC测温/I2S音频 |
| 48 |
P5.2/RxD4_2/PWM7_4/QSPIIO2_2 |
Flash存储器 |
| 1 |
P5.3/TxD4_2/PWM8_4/QSPIIO3_2 |
TFT彩屏/Flash存储器 |
| 15 |
P5.6/XTALO/MCLKO_2 |
无源晶振 |
| 16 |
P5.7/XTALI |
无源晶振 |
| 41 |
Vcc/ADC_AVcc/ADC_VRef+ |
| 29 |
UCAP |
| 17 |
ADC_Vref-/ADC_AGnd/Gnd |
实验箱外观
实验箱各功能模块
系统模块(点击展开详情)
AI8051U-34K64-LQFP48单片机
这款单片机是AI公司最新推出的划时代的8051单片机,具有无数先进的功能。
其具备完整的P0,P1,P2,P3端口,此外还有大部分P4和P5端口(缺P4.4,P5.4,P5.5),共计45个IO端口。其余3个端口分别是VCC,GND,以及供USB模块内部使用的UCAP电容脚
扩展32KB RAM电路P0,P2,P3.6,P3.7,P4.1,P4.5
这是8051单片机的传统扩展RAM电路,SRAM的访问也是通过硬件自动完成的(当然也可以在程序中手动操作这些引脚)
由于AI8051U已经集成了32KB的片内External SRAM,SRAM容量充足,因此用于扩展的SRAM芯片IS62C256和搭配使用的573锁存器芯片仅预留焊盘,实际未焊接。
#define ExternalRAM_enable() AUXR |= 2 //允许外部XRAM,禁止使用内部1024RAM
#define InternalRAM_enable() AUXR &= ~2 //禁止外部XRAM,允许使用内部1024RAM
具体用到的是这些复用功能(虽然8051允许最大64K RAM,但因为这个板子外置的是32K RAM,所以只需要15根地址线,第16根地址线P2.7 A15未连接)
另附一张考古图,来自英特尔1994年的 MCS@51 MICROCONTROLLER FAMILY USER'S MANUAL.pdf ,用当年的手绘示意图清晰地描述了这种接法
复位按钮电路P4.7
与STC89C52RC等传统51单片机最直观的区别就是,复位引脚变成了低电平复位。这也是和欧美其他单片机公司的新产品一致的做法。
需要在ISP软件或寄存器中配置为复位脚,该引脚方可用做复位脚,否则用做普通IO
32.768kHz晶振电路P5.6,P5.7
同时还可用于“自动追频”功能,进一步校准内部IRC高速时钟,同时确保了低功耗
晶振引脚不仅支持32.768kHz晶振,还支持连接高速晶振(支持12MHz以下无源晶振晶振,同时最高支持48MHz无源晶振)
接高速晶振时,功耗稍大,软件配置方法不同。走的是内部不同的时钟通路
传统模块(点击展开详情)
8灯流水灯电路P0,P4.0
流水灯为共阳极接法,P0端口输出低电平可以点亮对应的LED灯,阳极电源由P4.0连接的一个PNP三极管控制,P4.0输出低电平时,流水灯模块可以点亮。
独立按键电路(低电平有效)P3.2,P3.3,P3.4,P3.5
这四个独立按键均为低电平有效,且为外置上拉电阻。因此要求在程序中对这些端口启用上拉电阻,或使用带有弱上拉的准双向输入模式。
P3.2在USB HID的ISP下载过程中需要用到
P3.3可以在ISP下载时要求置低电平
8键2x4矩阵按键电路P0.0,P0.1,P0.2,P0.3,P0.6,P0.7
这是一个2x4的矩阵按键,有2行,4列。扫描时可以分2行进行,分别检查是否有按下的按钮。
矩阵按键与流水灯共用P0端口
每个IO的连线均有一个300Ω电阻,可以避免按钮影响流水灯的正常工作,还可以为避免矩阵扫描过程中,推挽输出的高低电平IO冲突,造成IO口的大电流
电路中不可避免地对P0.6和P0.7进行了10.3kΩ的上拉,在使用中需注意
16键ADC按钮电路P1.0
这16个按键位于16个电阻串的每个节点上,电阻串连接至SYS-VCC(VREF+)和GND。因此各节点可以均分ADC的整个量程。
按下某个按钮时,对应节点的电压将经过R50和C24的低通滤波,送至P1.0口进行ADC采集。
原理图中给出了每个按钮按下时的理论ADC读数值。
74HC595驱动的8位数码管P3.2,P3.4,P3.5
74HC595是一款非常简单易用的串入并出移位锁存寄存器芯片,可以在只使用3个单片机IO的条件下,方便地实现较多数量的IO输出扩展。(74HC164其实更简单,只需要2个单片机IO,它不带锁存功能)
在数码管电路中,使用了2片74HC595级联,实现了16个输出IO的扩展,分别连接至数码管的8条位线(控制哪一个数字位点亮)和8条段线(控制数字位中的哪些笔画点亮)
使用该移位寄存器芯片时,在11脚SCK的上升沿前,在14脚DATA送出一位数据。循环16次后,可以送出16位数据,该数据将会暂存在移位寄存器芯片内(8-bit storage register)。随后给12脚RCK一个上升沿,暂存的数据就会进入3-state outputs,输出到Q0~Q7端口上
数据手册如下:
附件:74HC_HCT595.pdf
红外接收电路P3.5
这是家电和单片机开发板上非常常见的一体式红外接收头。
内置了38kHz带通滤波电路、AGC自动增益电路、ASK解调电路等信号处理电路,单片机需要使用外部中断或轮询的方式,接收并处理输出波形。
红外发射电路P2.7
可以与红外接收头搭配使用,实现无线数据传输功能(
由于红外发射需要使用38kHz的载波频率进行ASK调制,因此P2.7使用38kHz的PWM进行驱动为宜(传统51单片机只能使用定时器中断或轮询方式产生38kHz的频率)
说来也巧,P2.7确实支持PWM
P2.7经过J17跳线帽(位于实验箱右上角,红外发射LED旁)连接至NPN三极管Q4,因此P2.7高电平对应红外发射LED工作。不发射时,P2.7应当处于低电平。
DS18B20单线数字温度传感器P3.3
DS18B20是一款51单片机常用的单线数字温度传感器。
信号线通过J10跳线与P3.3连接,跳线位于实验箱左下方
数据手册如下:
附件:DS18B20.pdf
NTC测温电路P1.3,P5.1
NTC测温电路是一种模拟温度传感器,与示波器输入共用P1.3口,通过跳线JUP2的位置选择。
NTC电路的供电由P5.1提供,而并非始终通电,应当是为低功耗实验做的处理
这里似乎有一处排版问题,NTC的规格应为10k@25℃,而图中出现了乱码
24C02 2Kbit EEPROM芯片电路P3.2,P3.3
这是一款常见的I2C芯片,是一颗可存储2Kbit=256字节数据的EEPROM芯片。由于其3个外部地址脚均接地,因此它的I2C 7位地址为1010000。写入时,其地址为10100000,即0xA0;读取时,其地址为10100001,即0xA1
这里24C02的第3脚名字写错了哦,应当为A2。
数据手册如下:
附件:AT24C01D-AT24C02D-I2C-Compatible-Two-Wire-Serial-EEPROM-1Kbit-2Kbit-20006100A.pdf
无源蜂鸣器P5.0
无源蜂鸣器使用一个NPN型三极管驱动,三极管受P5.0口控制,高电平动作。
由于是无源蜂鸣器,需要使用PWM信号输出方波,才可以使无源蜂鸣器鸣叫
无独有偶,P5.0真的支持PWM输出
由于P5.0同时用作I2S芯片,因此为避免I2S工作时,蜂鸣器乱叫,因此蜂鸣器与P5.0采用跳线帽隔开。使用无源蜂鸣器需要插好J1的第三排跳线帽
高级显示模块(点击展开详情)
12864显示屏插座P2,P3.6,P3.7,P4.5,P4.7
用于连接市面上常见的这款12864并口单色液晶屏
引脚说明:
4/7/8针I2C/SPI OLED插座P1.1,P3.2,P3.3,P3.5,P4.7
用于连接市面上常见的4针I2C或7针SPI接口的单色OLED屏幕模块
P3.2和P3.3恰好连接至片内硬件I2C模块
同时,P3.2,P3.3和P3.5恰好连接至片内硬件SPI模块(OLED模块只需要MOSI,不需要MISO)
而P3.3是MISO,并不是MOSI,因此使用时需要配置交换MISO和MOSI。这样就可以享受先进的硬件SPI技术了
TFT彩屏接口P2,P0.4,P0.5,P1.4,P1.5,P3.2,P3.3,P3.4,P3.6,P3.7,P4.5,P4.7,P5.3
这是一个Arduino Uno兼容的排母。
首选用于连接冲哥2.4寸电阻触摸屏,有触摸处理芯片,触摸更精准,更省资源
也支持原版Arduino Uno 2.4寸电阻触摸扩展板,无触摸处理芯片,需要ADC采集触摸状态。但是屏幕价格更低
原版屏引脚定义如下(其中WR和RS复用作电阻触控ADC检测端口,D7和D6复用做电阻触控偏置输出端口,且使用5V供电,需要微调实验箱预留的电阻R84和R99)
冲哥屏将microSD卡座移除,相应引脚改为了触摸处理芯片的通讯引脚
音频处理模块(点击展开详情)
TLV320AIC3204 I2S立体声音频芯片P1.4,P1.5,P1.6,P1.7,P5.0,P5.1
(似乎是笔记没有删?)
P1.4,P1.5,P1.6,P1.7恰好对应了单片机的I2S硬件模块
这款芯片支持最高48kHz采样率的音频输出。也支持音频采样,但实验箱未实现该功能。
芯片数据手册:
附件:tlv320aic3204.pdf
话筒输入电路P1.2
音频信号经过运算放大器放大、滤波后,直接输入给P1.2口,使用片内ADC进行音频采集
高性能示波器模块
示波器电路P0.0,P0.1,P0.2,P1.1,P1.3
图中讲解已经非常详细了
这个示波器电路支持如下特性:
- 直流耦合与交流耦合(通过J1跳线的第一行选择)
- 可调增益(1~200倍,通过模拟开关选择)
- 垂直平移调整(垂直基线0~1V)
由于使用了BNC接口,因此示波器探头或BNC转接线需自备
正弦波/方波信号源P2.3,P0.7
P2.3输出1000Hz正弦的PWM信号,处理得到纯净的1000Hz正弦波
P0.7输出1000Hz方波的PWM信号,直接引出得到1000Hz方波
串口通讯模块(点击展开详情)
USB及Link1D电路P3.0,P3.1
P3.0和P3.1既是UART串口、也是SWD调试口、也是USB口
因此可以直接连接电脑USB口,也可以连接USB Link1D进行SWD实时调试,还可以用传统方式连接USB串口模块
板载AI8H USB转双串口芯片P3.6,P3.7,P4.2,P4.3
板载AI8H MCU,用做USB转双串口芯片,提供了2个USB串口。引出的P3.2按钮可实现该MCU通过USB进行ISP固件更新
一箭双雕串口板连接器电路P3.6,P3.7,P4.2,P4.3
与一箭双雕串口板线序一致,可以认为板上集成了一箭双雕串口板,或认为可以外接一箭双雕串口板
双串口互传 P3.6,P3.7,P4.2,P4.3
用于将MCU的两路串口交叉相连,实现数据左右互搏?
RS-485收发器电路P4.2,P4.3
采用了自动流向控制电路的RS-485方案,集成了120Ω终端电阻,RS-485信号线通过XH2.54端子引出
存储模块(点击展开详情)
W25Q128JV 128Mbit SPI/QSPI Flash存储器电路P4.0,P4.1,P4.2,P4.3,P5.2,P5.3
虽然原理图写的是W25Q80这款容量仅为8Mbit的SPI Flash芯片(人民币1元),但板子实际焊接的是容量高达128Mbit的W25Q128JV存储器芯片(人民币2元)。赞美AI公司
P4.0,P4.1,P4.2,P4.3,P5.2,P5.3恰好为MCU的硬件QSPI接口位置,可直接使用硬件功能
数据手册如下:
附件:W25Q128JV RevJ 04252024 Plus.pdf
microSD卡座P2.4,P2.5,P2.6,P2.7
AI8051U不支持SDIO硬件功能。但P2.4,P2.5,P2.6,P2.7恰好为MCU的硬件SPI接口位置,可直接使用SPI硬件功能与microSD卡通讯
电源部分(点击展开详情)
板载3.3V主LDO、RTC后备电池及按键断电电路
来自三个USB的5V供电经过自恢复保险丝R19(为什么是R呢?),得到USB+5V电源,该电源为3.3V LDO ME6231C33提供输入。
ME6231C33默认状态下CE脚被上拉,LDO处于工作状态。按下Power_SW按钮后,CE脚被拉低,LDO切断输出。
输出防反流的P-MOS管Q3的栅极连接到了USB端的NPN三极管Q13的集电极。具体原理如下(感谢 @梁工 的耐心答复,答疑帖 https://www.stcaimcu.com/forum.php?mod=redirect&goto=findpost&ptid=12528&pid=127943)
三极管做比较器,MSOFET做开关。
当USB输入电压为5V时,三极管导通,从而MOSFET也导通,压降非常小,小于10mV。
当USB端口,电压下降到低于3.5V左右,三极管截止,从而MOSFET也截止,备用电池电流不会倒流到稳压电源电路。
以上电路实现功能:USB-5V供电时,稳压为3.3V给系统供电,USB断开供电时,备用电池供电,电源电路不耗电。
-3.3V负电源电荷泵电路
为正弦波信号发生器、示波器等电路中的精密运算放大器提供-3.3V的负电源。
掉电检测比较器P4.6
电位器W1(位于数码管右下方)+R2分压电阻 得到一个与USB+5V电源成正比的电压值,输入至P4.6口
详见AI8051U数据手册
