查看: 2652|回复: 3
STC8H3K64S2 EEPROM 操作
发表于 2023-3-4 14:42:19 | 显示全部楼层 |阅读模式
主控型号: STC8H3K64S2
用户EEPROM大小为1K(下载程序时配置)
  1. //sfr IAP_CMD   = 0xC5;
  2. #define IAP_STANDBY()   IAP_CMD = 0     //IAP空闲命令(禁止)
  3. #define IAP_READ()      IAP_CMD = 1     //IAP读出命令
  4. #define IAP_WRITE()     IAP_CMD = 2     //IAP写入命令
  5. #define IAP_ERASE()     IAP_CMD = 3     //IAP擦除命令
  6. //sfr IAP_TRIG  = 0xC6;
  7. #define IAP_TRIG()  do{ IAP_TRIG = 0x5A,    IAP_TRIG = 0xA5 } while(0)     // IAP触发命令
  8. //                                      7    6    5      4    3   2  1   0   Reset Value
  9. //sfr IAP_CONTR = 0xC7;     IAPEN SWBS SWRST CFAIL  -   -  -   -   0000,x000    //IAP Control Register
  10. #define IAP_EN              (1<<7)
  11. #define IAP_SWBS            (1<<6)
  12. #define IAP_SWRST           (1<<5)
  13. #define IAP_CMD_FAIL        (1<<4)
  14. #define IAP_ENABLE()        do{ IAP_CONTR = IAP_EN; IAP_TPS = MAIN_Fosc / 1000000; } while(0)
  15. #define IAP_DISABLE()       do{ IAP_CONTR = 0; IAP_CMD = 0; IAP_TRIG = 0; IAP_ADDRH = 0xff; IAP_ADDRL = 0xff; } while(0)
  16. void F_EEPROM_Test(void)
  17. {
  18.     u16 EE_address = 0xFC00;
  19.     u8 WrDataBuf[9] = {0x55,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08};
  20.     u8 RdDataBuf[9] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  21.     u16 number;
  22.     EA = 0;     //禁止中断
  23.     // 先擦除
  24.     IAP_ENABLE();           //设置等待时间,允许IAP操作,送一次就够
  25.     IAP_ERASE();                        //宏调用, 送扇区擦除命令,命令不需改变时,不需重新送命令
  26.                                         //只有扇区擦除,没有字节擦除,512字节/扇区。
  27.                                         //扇区中任意一个字节地址都是扇区地址。
  28.     IAP_ADDRH = (EE_address) / 256;       //送扇区地址高字节(地址需要改变时才需重新送地址)
  29.     IAP_ADDRL = (EE_address) % 256;       //送扇区地址低字节
  30.     //触发EEPROM操作
  31.     IAP_TRIG = 0x5a; //写触发命令(0x5a)
  32.     IAP_TRIG = 0xa5; //写触发命令(0xa5)
  33.     _nop_();
  34.     // 写
  35.     IAP_ENABLE();           //设置等待时间,允许IAP操作,送一次就够
  36.     IAP_WRITE();                        //宏调用, 送扇区擦除命令,命令不需改变时,不需重新送命令
  37.     for (number = 0; number < 9; ++number)
  38.     {
  39.                                             //只有扇区擦除,没有字节擦除,512字节/扇区。
  40.                                             //扇区中任意一个字节地址都是扇区地址。
  41.         IAP_ADDRH = (EE_address) / 256;       //送扇区地址高字节(地址需要改变时才需重新送地址)
  42.         IAP_ADDRL = (EE_address) % 256;       //送扇区地址低字节
  43.         IAP_DATA = WrDataBuf[number];
  44.         //触发EEPROM操作
  45.         IAP_TRIG = 0x5a; //写触发命令(0x5a)
  46.         IAP_TRIG = 0xa5; //写触发命令(0xa5)
  47.         _nop_();
  48.         EE_address++;
  49.     }
  50.     EE_address = 0xFC00;
  51.     IAP_ENABLE();           //设置等待时间,允许IAP操作,送一次就够
  52.     IAP_READ();             //送字节读命令,命令不需改变时,不需重新送命令
  53.     for (number = 0; number < 9; ++number)
  54.     {
  55.         IAP_ADDRH = EE_address / 256; //设置 IAP 地址高字节
  56.         IAP_ADDRL = EE_address % 256; //设置 IAP 地址低字节
  57.         IAP_TRIG = 0x5a; //写触发命令(0x5a)
  58.         IAP_TRIG = 0xa5; //写触发命令(0xa5)
  59.         _nop_();
  60.         _nop_();
  61.         RdDataBuf[number] = IAP_DATA; //读 IAP 数据
  62.         EE_address++;
  63.     }
  64.     // 判断写入与读出数据是否相同
  65.     for (number = 0; number < 9; ++number)
  66.     {
  67.         if(RdDataBuf[number] != WrDataBuf[number])
  68.         {
  69.             break;
  70.         }
  71.     }
  72.     if(number < 9)
  73.     {
  74.         P55 = 0;
  75.         _nop_();    // 不同 仿真运行时跳到此处
  76.     }
  77.     else
  78.     {
  79.         P55 = 1;
  80.         _nop_();    // 相同
  81.     }
  82.     EA = 1;     //使能中断
  83. }
能不能帮看看是哪的问题?谢谢.
另外问一下,写FLASH完成后,能不能有Memory里观察到数据的变化?
还在STC-ISP里的EEPROM文件这设置的EEPROM数据,通过下载到MCU后,在Memory只能看到代码部分是有数据(非0xff),
但EEPROM数据看不到,还是这颗IC,EEPROM空间为1K,那EEPROM数据应该是从0xFC00开始存放吧?
发表于 2023-3-4 17:43:28 | 显示全部楼层
STC8系列的EEPROM操作的地址是相对地址,不是Flash的绝对地址。
烧录时EEPROM大小设置1K的话,EEPROM的地址范围就是0000H~03FFH之间,不能使用0xFC00作为EEPROM操作地址。
可将EEPROM内容读取到全局变量里面观察,或者通过串口打印出来查看。
另外需要注意,烧录(包括仿真点击DEBUG按钮)时,在将程序烧写到芯片前会先擦除Flash,EEPROM里面的数据也会被擦除。
 楼主| 发表于 2023-3-4 21:00:27 | 显示全部楼层
烧录时EEPROM大小设置1K的话,EEPROM的地址 ...
例如:STC8H1K28 这个型号的 FLASH为 28K,此时若用户想分出其中的 8K 作为 EEPROM 使用则EEPROM 的物理地址则为28K 的最后 8K,物理地址为 5000h~6FFFh,
当然,用户若使用IAP 的方式进行访问,目标地址仍然从 0000h 开始,到 1FFFh 结束
当使用 MOVC 读取则需要从 5000h 开始,到6FFFh 结束
注意: STC8HIK28 这个型号的程序空间为 28K,即整个 28K 的范围均可运行程序,即使在ISP 下载时将 28K 最后的 8K 设置为 EEPROM 使用,
但这分配的 8K 空间仍然可以运行程序。其它可自定义 EEPROM 大小的型号与此类似。
感谢,还是看资料不够仔细.
防止其它人犯同样的错误,再将这个说明加上来.
其实这个备注可以再加到范例部分去.
 楼主| 发表于 2023-3-4 21:02:30 | 显示全部楼层
即,MCU设置EEPROM区间为从后开始算.但IAP方式仿真却是从00开始.MOVC才是从实际FLASH地址开始.
GMT+8, 2026-9-23 16:10 , Processed in 0.067387 second(s), 54 queries .
