- 打卡等级:以坛为家III
- 打卡总天数:760
- 最近打卡:2026-03-24 17:46:08
- 积分
- 3065
用 AI8G1K08-20P,ULN2003A ,驱动 28BYJ-48歨进电机的电路是不是有问题,上电没反应,断开P30就可以正常上电。
但是上电后启动M3步进电机时,电机一直在振动,要帮它扭一扭转轴才能转起来,
我在KEIL里手动仿真,发现在第一次循环到 case 3 结束之后会异常 跳转到扫描按键的中断里面去,之后就能正常循环
if (ucKeySec == 1)
switch(num2)
case 0:M3A = 1;M3B = 0;M3C = 0;M3D = 0;break;
case 1:M3A = 1;M3B = 1;M3C = 0;M3D = 0;break;
case 2:M3A = 0;M3B = 1;M3C = 0;M3D = 0;break;
case 3:M3A = 0;M3B = 1;M3C = 1;M3D = 0;break;
case 4:M3A = 0;M3B = 0;M3C = 1;M3D = 0;break;
case 5:M3A = 0;M3B = 0;M3C = 1;M3D = 1;break;
case 6:M3A = 0;M3B = 0;M3C = 0;M3D = 1;break;
case 7:M3A = 1;M3B = 0;M3C = 0;M3D = 1;break;
delay1m(3);
num2++;
if(num2 == 8)num2 = 0;
if (Ir2_time == 1)
ucKeySec = 0;
sec_flag = 1;
if (sec_cnt == 3)
static int cyc1 = 1529;
sec_cnt = 0;
sec_flag = 0;
while (cyc1--)
switch(num1)
case 0:M2A = 1;M2B = 0;M2C = 0;M2D = 0;break;
case 1:M2A = 1;M2B = 1;M2C = 0;M2D = 0;break;
case 2:M2A = 0;M2B = 1;M2C = 0;M2D = 0;break;
case 3:M2A = 0;M2B = 1;M2C = 1;M2D = 0;break; //这里,在弟一次运行到这行结束后会跳转到按键扫描中断里,第2次及以后就可正常循环到 case 4
case 4:M2A = 0;M2B = 0;M2C = 1;M2D = 0;break;
case 5:M2A = 0;M2B = 0;M2C = 1;M2D = 1;break;
case 6:M2A = 0;M2B = 0;M2C = 0;M2D = 1;break;
case 7:M2A = 1;M2B = 0;M2C = 0;M2D = 1;break;
delay1m(3);
//num1++;
if(++num1 == 8)num1 = 0;
Ir2_time = 0;
ucKeySec = 1;
void TM0_Isr() interrupt 1
TF0 = 0; /*清除中断标志*/
TR0 = 0; /*关中断*/
/*扫描按键*/
Key_Scan();
TL0 = 0xCD; //设置定时初值
TH0 = 0xD4; //设置定时初值
TR0 = 1; /*开中断*/
截图202411151348026273.jpg |
