查看: 1092|回复: 9
定时器与串口通信同时工作
  • 打卡总天数:130
  • 最近打卡:2026-03-23 15:12:56
发表于 2024-11-15 09:40:55 | 显示全部楼层 |阅读模式
问大家个问题,我用串口2与ESP8266发送数据到手机APP上,用定时器T0作为定时,coun为定时时间,count%7==0,每7秒发送,count计时到60秒,但为什么每发送一次,count会自动会回到初始值呢,液晶显示程序太多了,就只上传了一部分{:5_358:},液晶能够正常显示数字,下面是部分主要程序
主程序:
#include "main.h"
#include "stc8.h"
#include "lcd1602.h"
#include "ESP8266.h"
#include "uart2.h"
#include "string.h"
#define     MAIN_Fosc       11059200UL
#define Timer0_Reload   (65536UL -(MAIN_Fosc/240))
unsigned char buf_flag[]={0};
unsigned char  flg=0,count=0;
unsigned char dataBuf[]={0};
void setinoutport()
        P0M1=0X00;P0M0=0X00;
        P1M1=0X00;P1M0=0X02;
        P2M1=0X00;P2M0=0X00;
        P3M1=0X00;P3M0=0X02;
        P0PU=0XFF;
void LCD_Initial(void)//液晶初始化
   LCD1602_WriteCmd(0x38);
   LCD1602_WriteCmd(0x0C);
   LCD1602_WriteCmd(0x01);
         LCD1602_WriteCmd(0x06);
void esp8266int()//ESP8266初始化
        PrintString("AT\r\n",4);
        PrintString("ATE0\r\n",6);
        PrintString("AT+CWMODE=2\r\n",13);
        PrintString("AT+CWSAP=\"ESP8266\",\"666666666\",6,4\r\n",34);
        PrintString("AT+RST\r\n",8);
        PrintString("AT+CIPMUX=1\r\n",13);
        PrintString("AT+CIPSERVER=1,8090\r\n",21);
void tim0int()
        AUXR &= 0x7F;
        TMOD = 0xF0;
        TL0 = Timer0_Reload%256;
        TH0 = Timer0_Reload/256;
        TF0=0;
        ET0 = 1;
        EA = 1;     //´ò¿ª×ÜÖжÏ
        TR0 = 1;
void Print(u8 x,u8 y, u8 dat)//液晶显示程序
         u8 address;
                if(y==0)
                address=0x80+x;
        address=0xC0+x;
    LCD1602_WriteCmd(address);
    LCD1602_WriteData(dat);
main()
        setinoutport();
        LCD_Initial();
        uart1int();
        uart2int();
        esp8266int();
        tim0int();
        for(;;)
                Print(14,1,count/10+'0');
                Print(15,1, count%10+'0');//液晶显示count计数值
                if(count%7)
                sprintf(dataBuf,"Temp:%3.1fC\r\n",32.5);
                PrintString("AT+CIPSEND=0,12\r\n",17);                //·¢ËÍÊý¾Ý
                DelayMs(500);
                PrintString(dataBuf,12);//串口2发送数据到ESP8266
                DelayMs(500);
                Print(6,1, flg1+'0');
                Print(1,1, 3+'0');
void fxt0(void) interrupt 1
        static unsigned char B_ms;
         B_ms ++;      //50ms++
          if(B_ms>20)
                        B_ms=0;
                        count++;
                        if(count>60) count=1;
串口子程序
#include "stc8.h"
#include "main.h"
#include "string.h"
extern  unsigned char RX_num=0,RX_i=0;
extern unsigned char  RX_buffer[]={0};
unsigned char  tbuf=100,i=0;
bit busy2,busy1;
sbit LED2                =        P1^6;
extern unsigned  char flg1=6;
void DelayUs2x(unsigned char t)
while(--t);
void uart1int(void)
        SCON = 0x50;                //8???,?????
        AUXR |= 0x01;                //??1?????2???????
        AUXR |= 0x04;                //?????1T??
        T2L = 0xE0;                        //???????
        T2H = 0xFE;                        //???????
        AUXR |= 0x10;                //???2????
  ES=1;
        EA=1;
void uart2int(void)        // 9600bps@11.0592MHz
        S2CON = 0x50;
        AUXR |= 0x04;
        AUXR |= 0x01;
        T2L   = 0xE0;
        T2H   = 0xFE;
        AUXR |= 0x10;
        IE2   = 0x01;
        EA    = 1;
void Uart1_SendChar(unsigned char Udat)
        SBUF=Udat;
        while(!TI);
  TI=0;
void Uart1_Send_Data(u8 *Buf , u8 len)
         unsigned char i;
        for(i=0;i<len;i++)
                Uart1_SendChar(*(Buf+i));
void Uart1_Isr() interrupt 4
        if(RI)
                RI=0;
void PrintString(unsigned char  *puts,unsigned char  tt)
        unsigned char NUM=0;
                 for (; NUM<tt;  puts++)
        S2BUF = *puts;
        NUM++;
        busy2 = 1;
        while(busy2);
void Uart2() interrupt 8
        IE2&=0Xfe;
    if (S2CON & S2RI)
                        S2CON =0x50;
                        RX_buffer[RX_num] = S2BUF;
                        if(RX_buffer[0]=='+')
                            RX_num++;
          if(RX_buffer[RX_num-1]=='-')
                                        if(RX_buffer[RX_num-2]=='1') {LED2=1;flg1=1;RX_num=0;}
                                        if(RX_buffer[RX_num-2]=='2') {LED2=0;flg1=2;RX_num=0;        }
                        else {RX_num=0;}
                        if(RX_num>tbuf)
                                RX_num = 0;
    if (S2CON & S2TI)
                        S2CON =0x50;
       busy2 = 0;
                IE2|=0X01;
  • 打卡总天数:255
  • 最近打卡:2026-03-26 08:51:21
发表于 2024-11-15 11:02:52 | 显示全部楼层
这个地方应该是这样
if(B_ms>20)
        B_ms=0;
        count++;
        if(count>=60) count=0;
但这应该不是你说的问题的原因
  • 打卡总天数:255
发表于 2024-11-15 11:05:15 | 显示全部楼层
if(count%7==0)
这也达不到每7秒发送一次的目的,因为60不是7的公倍数,可以计数到63后归0
  • 打卡总天数:130
发表于 2024-11-15 11:14:06 来自手机 | 显示全部楼层
bkeuqoaq 发表于 2024-11-15 11:05
if(count%7==0)
这也达不到每7秒发送一次的目的,因为60不是7的公倍数,可以计数到63后归0 ...
但是1---60中的7  14  21  28  35  42  49  56这些数是7的倍数,可以发送数
  • 打卡总天数:844
  • 最近打卡:2026-03-26 07:56:01
发表于 2024-11-15 11:15:29 | 显示全部楼层
count是局部变量?或者不是静态变量
  • 打卡总天数:130
发表于 2024-11-15 11:16:08 来自手机 | 显示全部楼层
关键是串口每发送一次数据,count计数值就变成1了,我感觉串口发送数据时,干扰了定时器0的计数功能,我在串口发送数据时,将定时器0关闭了,送完再打开,还是不行的
  • 打卡总天数:255
发表于 2024-11-15 11:16:39 | 显示全部楼层
是的
  • 打卡总天数:130
发表于 2024-11-15 12:26:59 来自手机 | 显示全部楼层
jwd 发表于 2024-11-15 11:15
count是局部变量?或者不是静态变量
count我定义的是全局变量
  • 打卡总天数:296
  • 最近打卡:2026-01-08 10:11:26
发表于 2024-11-15 13:45:57 | 显示全部楼层
代码不完整,而且代码与内文不符
main函数在哪?
Timer0_Reload在哪定义?
只看到串口1的初始化
串口2的初始化呢?
  • 打卡总天数:130
发表于 2024-11-15 15:29:57 | 显示全部楼层
Lkck*** 发表于 2024-11-15 13:45
代码不完整,而且代码与内文不符
main函数在哪?
Timer0_Reload在哪定义?
现在程序完整了{:5_284:}
GMT+8, 2026-3-26 13:05 , Processed in 0.112398 second(s), 88 queries .
