查看: 930|回复: 3
建议扩展特殊功能寄存器地址的排序
发表于 2024-11-11 13:47:52 | 显示全部楼层 |阅读模式
现在扩展特殊功能寄存器地址的排序
#define     P0PU                    (*(unsigned char volatile far *)0x7efe10)
#define     P1PU                    (*(unsigned char volatile far *)0x7efe11)
#define     P2PU                    (*(unsigned char volatile far *)0x7efe12)
#define     P3PU                    (*(unsigned char volatile far *)0x7efe13)
#define     P4PU                    (*(unsigned char volatile far *)0x7efe14)
#define     P5PU                    (*(unsigned char volatile far *)0x7efe15)
#define     P6PU                    (*(unsigned char volatile far *)0x7efe16)
#define     P7PU                    (*(unsigned char volatile far *)0x7efe17)
#define     P0NCS                   (*(unsigned char volatile far *)0x7efe18)
#define     P1NCS                   (*(unsigned char volatile far *)0x7efe19)
#define     P2NCS                   (*(unsigned char volatile far *)0x7efe1a)
#define     P3NCS                   (*(unsigned char volatile far *)0x7efe1b)
#define     P4NCS                   (*(unsigned char volatile far *)0x7efe1c)
#define     P5NCS                   (*(unsigned char volatile far *)0x7efe1d)
#define     P6NCS                   (*(unsigned char volatile far *)0x7efe1e)
#define     P7NCS                   (*(unsigned char volatile far *)0x7efe1f)
#define     P0SR                    (*(unsigned char volatile far *)0x7efe20)
#define     P1SR                    (*(unsigned char volatile far *)0x7efe21)
#define     P2SR                    (*(unsigned char volatile far *)0x7efe22)
#define     P3SR                    (*(unsigned char volatile far *)0x7efe23)
#define     P4SR                    (*(unsigned char volatile far *)0x7efe24)
#define     P5SR                    (*(unsigned char volatile far *)0x7efe25)
#define     P6SR                    (*(unsigned char volatile far *)0x7efe26)
#define     P7SR                    (*(unsigned char volatile far *)0x7efe27)
#define     P0DR                    (*(unsigned char volatile far *)0x7efe28)
#define     P1DR                    (*(unsigned char volatile far *)0x7efe29)
#define     P2DR                    (*(unsigned char volatile far *)0x7efe2a)
#define     P3DR                    (*(unsigned char volatile far *)0x7efe2b)
#define     P4DR                    (*(unsigned char volatile far *)0x7efe2c)
#define     P5DR                    (*(unsigned char volatile far *)0x7efe2d)
#define     P6DR                    (*(unsigned char volatile far *)0x7efe2e)
#define     P7DR                    (*(unsigned char volatile far *)0x7efe2f)
#define     P0IE                    (*(unsigned char volatile far *)0x7efe30)
#define     P1IE                    (*(unsigned char volatile far *)0x7efe31)
#define     P2IE                    (*(unsigned char volatile far *)0x7efe32)
#define     P3IE                    (*(unsigned char volatile far *)0x7efe33)
#define     P4IE                    (*(unsigned char volatile far *)0x7efe34)
#define     P5IE                    (*(unsigned char volatile far *)0x7efe35)
#define     P6IE                    (*(unsigned char volatile far *)0x7efe36)
#define     P7IE                    (*(unsigned char volatile far *)0x7efe37)
#define     P0PD                    (*(unsigned char volatile far *)0x7efe40)
#define     P1PD                    (*(unsigned char volatile far *)0x7efe41)
#define     P2PD                    (*(unsigned char volatile far *)0x7efe42)
#define     P3PD                    (*(unsigned char volatile far *)0x7efe43)
#define     P4PD                    (*(unsigned char volatile far *)0x7efe44)
#define     P5PD                    (*(unsigned char volatile far *)0x7efe45)
#define     P6PD                    (*(unsigned char volatile far *)0x7efe46)
#define     P7PD                    (*(unsigned char volatile far *)0x7efe47)
#define     P0BP                    (*(unsigned char volatile far *)0x7efe48)
#define     P1BP                    (*(unsigned char volatile far *)0x7efe49)
#define     P2BP                    (*(unsigned char volatile far *)0x7efe4a)
#define     P3BP                    (*(unsigned char volatile far *)0x7efe4b)
#define     P4BP                    (*(unsigned char volatile far *)0x7efe4c)
#define     P5BP                    (*(unsigned char volatile far *)0x7efe4d)
#define     P6BP                    (*(unsigned char volatile far *)0x7efe4e)
#define     P7BP                    (*(unsigned char volatile far *)0x7efe4f)
建议扩展特殊功能寄存器地址的排序
#define     P0NCS                   (*(unsigned char volatile far *)0x7efe11)
#define     P0SR                    (*(unsigned char volatile far *)0x7efe12)
#define     P0DR                    (*(unsigned char volatile far *)0x7efe13)
#define     P0IE                    (*(unsigned char volatile far *)0x7efe14)
#define     P0PD                    (*(unsigned char volatile far *)0x7efe15)
#define     P0BP                    (*(unsigned char volatile far *)0x7efe16)
#define     P0INTE                  (*(unsigned char volatile far *)0x7efe17)
#define     P0INTF                  (*(unsigned char volatile far *)0x7efe18)
#define     P0IM1                    (*(unsigned char volatile far *)0x7efe19)
#define     P0IM0                   (*(unsigned char volatile far *)0x7efe1a)
#define     P0WKUE                   (*(unsigned char volatile far *)0x7efe1b)
typedef struct
        u8        PU;
        u8        NCS;
        u8        SR;
        u8        DR;
        u8        IE;
        u8        PD;
        u8        BP;
        u8 WKUE;
} GPIO_TypeDef;
GPIO_TypeDef far *GPIOP0 = &P0PU;
GPIO_TypeDef far *GPIOP1 = (&P0PU) + xx;
GPIO_TypeDef far *GPIOP2 = (&P0PU) + xx;
GPIO_TypeDef far *GPIOP3 = (&P0PU) + xx;
GPIO_TypeDef far *GPIOP4 = (&P0PU) + xx;
GPIO_TypeDef far *GPIOP5 = (&P0PU) + xx;
GPIO_TypeDef far *GPIOP6 = (&P0PU) + xx;
GPIO_TypeDef far *GPIOP7 = (&P0PU) + xx;
        GPIOP0->PU = 0XFF;
        while (1);
还有很多地方
退了
发表于 2024-11-11 14:23:02 | 显示全部楼层
你那是按端口排序,官网的是按功能排序吧
 楼主| 发表于 2024-11-11 14:57:00 来自手机 | 显示全部楼层
jwd 发表于 2024-11-11 14:23
你那是按端口排序,官网的是按功能排序吧
是的
退了
自定义头衔
发表于 2024-11-11 15:36:27 来自手机 | 显示全部楼层
确实按端口排序更适合结构体访问,也是各家mcu的通常做法
GMT+8, 2026-9-23 16:11 , Processed in 0.066027 second(s), 59 queries .
