查看: 2302|回复: 10
8g1k08a 8pin pca高速脉冲 p54不输出
  • 打卡总天数:9
  • 最近打卡:2026-04-14 16:55:09
发表于 2024-10-13 21:36:57 | 显示全部楼层 |阅读模式
#include "config.h"
#define     PCA_T1US        (MAIN_Fosc / 12 / 1000000)  // 1us 12分频
#define     PWM_DUTY        (20000*PCA_T1US)            // 20ms
u16 g_pwm_tmps[3];
u16 g_pwm_highs[3]={PCA_T1US*500, PCA_T1US*2500, PCA_T1US*500};
u16 g_pwm_lows[3]={PWM_DUTY-PCA_T1US*500, PWM_DUTY-PCA_T1US*2500, PWM_DUTY-PCA_T1US*500};
void PCA_Init(void)
    CCON = 0x00;
    CMOD = 0x00;                                //PCA时钟为系统时钟12分频
    CL = 0x00;
    CH = 0x00;
    CCAPM0 = 0x4d;                              //PCA模块0为16位定时器模式并使能脉冲输出
    g_pwm_tmps[0 = PCA_T1US*500;
    CCAP0L = g_pwm_tmps[0];
    CCAP0H = g_pwm_tmps[0 >> 8;
    g_pwm_tmps[0 += PCA_T1US*500;
    CCAPM1 = 0x4d;                              //PCA模块0为16位定时器模式并使能脉冲输出
    g_pwm_tmps[1 = PCA_T1US*500;
    CCAP1L = g_pwm_tmps[1];
    CCAP1H = g_pwm_tmps[1 >> 8;
    g_pwm_tmps[1 += PCA_T1US*500;
    CCAPM2 = 0x4d;
    g_pwm_tmps[2 = PCA_T1US*500;
    CCAP2L = g_pwm_tmps[2];
    CCAP2H = g_pwm_tmps[2 >> 8;
    g_pwm_tmps[2 += PCA_T1US*500;
    CR = 1;                                     //启动PCA计时器
void PCA_Isr() interrupt 7
    if(CCF0) {
        CCF0 = 0;
        if(P32) g_pwm_tmps[0 += g_pwm_highs[0];
        else    g_pwm_tmps[0 += g_pwm_lows[0];
    if(CCF1) {
        CCF1 = 0;
        if(P33) g_pwm_tmps[1 += g_pwm_highs[1];
        else    g_pwm_tmps[1 += g_pwm_lows[1];
    if(CCF2) {
        CCF2 = 0;
        if(P54) g_pwm_tmps[2 += g_pwm_highs[2];
        else   g_pwm_tmps[2 += g_pwm_lows[2];
    if(CF) CF = 0;
void delay_ms(unsigned char ms)
    unsigned int i;
    do{
        i = MAIN_Fosc / 1000;
        while(--i);
    }while(--ms);
    P3M0 = 0x00;
    P3M1 = 0x00;
        P5M0 &= ~0x10; P5M1 &= ~0x10;
    delay_ms(100);
    PCA_Init();
    // CR = 0;
    // g_pwm_highs[0] = 3000*PCA_T1US;
    // g_pwm_lows[0] = PWM_DUTY-g_pwm_highs[0];
    // g_pwm_highs[1] = 500*PCA_T1US;
    // g_pwm_lows[1] = PWM_DUTY-g_pwm_highs[1];
    // g_pwm_highs[2] = 4000*PCA_T1US;
    // g_pwm_lows[2] = PWM_DUTY-g_pwm_highs[2];
    // CR = 1;
    while (1);
  • 打卡总天数:712
  • 最近打卡:2026-07-03 09:07:06
发表于 2024-10-14 09:47:05 | 显示全部楼层
P54是黄色信号吗?
将P54设置推挽输出,或者断开外围电路,直接测量脚位信号试试。
  • 打卡总天数:9
发表于 2024-10-14 10:11:04 | 显示全部楼层
乘风*** 发表于 2024-10-14 09:47
P54是黄色信号吗?
将P54设置推挽输出,或者断开外围电路,直接测量脚位信号试试。 ...
是黄色信号, 设置过推挽输出也没用的, 现在没有外围电路, 仅用裸芯片量脚位信号的
  • 打卡总天数:656
  • 最近打卡:2026-07-05 09:47:08
发表于 2024-10-14 10:26:23 | 显示全部楼层
    P5M0 = 0x10; P5M1 = 0x00;
  • 打卡总天数:9
发表于 2024-10-14 10:30:53 | 显示全部楼层
这个我也试过了, 不太行
  • 打卡总天数:184
  • 最近打卡:2026-03-17 13:46:23
24
发表于 2024-10-14 11:18:41 | 显示全部楼层
注意EAXFR设置,最好初始化时候先打开
  • 打卡总天数:9
发表于 2024-10-14 11:30:43 | 显示全部楼层
请问这里我该怎么改呀? 感谢
  • 打卡总天数:9
发表于 2024-10-14 11:34:15 | 显示全部楼层
而且p32 p33都可以正常输出, 就p54不行
[attachimg]59709[/attachimg] 是否可能是这个选项选择错了?将IO变成复位引脚了  详情 回复 发表于 2024-10-14 11:38
  • 打卡总天数:738
  • 最近打卡:2026-07-04 20:08:40
发表于 2024-10-14 11:38:55 | 显示全部楼层
  • 打卡总天数:9
发表于 2024-10-14 11:40:31 | 显示全部楼层
是否我需要配置这些
GMT+8, 2026-7-5 12:29 , Processed in 0.090602 second(s), 91 queries .
