在聊天室看到一个国际友人发的消息, 我来帮他发个帖子.
In the online simulation, the output of S-VCC supplies 5V to the target system, but after using STCAI-ISP 6.94E, the output (S-VCC) is always 3.3V, and after switching back to STCAI-ISP 6.94D, the output (S-VCC) is 4.8V, and the system online simulation is normal. This problem should be caused by the program of LINK1D. Suggest STC to modify STCAI-ISP driver.
在线仿真中,S-VCC 的输出为目标系统提供 5V 电压,但使用 STCAI-ISP 6.94E 后,输出(S-VCC)始终为 3.3V,而切换回 STCAI-ISP 6.94D 后,输出(S-VCC)为 4.8V,系统在线仿真正常。此问题应由 LINK1D 的程序引起。建议 STC 修改 STCAI-ISP 驱动程序。
