楼主: tianpeng0
能不能用外部32768计算得到内部IRC的准确频率
  • 打卡总天数:3
  • 最近打卡:2024-10-31 10:38:52
发表于 2024-8-20 14:41:48 | 显示全部楼层
cdp*** 发表于 2024-8-20 05:53
如果已知外部频率,可以参考频率计做法,对外部晶振或其分频做计数,倒推内部时钟误差. ...
在只有单片机的情况下,无法做到内部IRC运行,又对外部RTC分频再引回单片机进行采样
  • 打卡总天数:3
发表于 2024-8-20 14:49:48 | 显示全部楼层
还是希望能够找到如C8051F411的捕获外部时钟的类似功能,
这个能很容易在一个计数周期内准确知道内部频率,
且与测量时段保持的足够近
  • 打卡总天数:12
  • 最近打卡:2025-10-04 11:54:26
发表于 2024-8-20 15:06:08 | 显示全部楼层
tianp*** 发表于 2024-8-20 14:39
用RTC的分频中断是个好主意,但无奈这个是个软件方案,非硬件方案,可能也是该款单片机目前最好的方案 ...
Yes, it is a hybrid HW/SW solution.
The SW overhead is modest, just 32 times a second it captures the 2 timer registers and exits.
The SW jitter on the interrupt should be well below the IRC oscillator drift/jitter and if you want to preserve long term drift,  you can read and add the timer values and never clear them.
I still hope to find a similar function like C8051F411 to capture the external clock, which can easily know the internal frequency accurately within a counting cycle and keep it close enough to the measurement period.
yes, STC are not great at cross domain capture, (or indeed much capture at all) so a pure hardware capture is not supported.
  • 打卡总天数:3
发表于 2024-8-20 15:18:27 | 显示全部楼层
The SW overhead is modest, just 32 times a second it captures  ...
这里面最本质的其实就是STC缺少一个RTC的可编程时钟输出,
无论是内部打线还是外部输出,
有了这个硬件上可以做的事情就多了很多。
  • 打卡总天数:226
  • 最近打卡:2025-11-02 10:12:27
792
发表于 2024-8-20 22:45:39 | 显示全部楼层
用 PWM/PCA 功能测量外部 32768 时钟是标准功能
  • 打卡总天数:12
发表于 2024-8-21 04:28:59 | 显示全部楼层
Do you have diagrams and examples for this ?
  • 打卡总天数:12
发表于 2024-8-21 04:30:38 | 显示全部楼层
无论是内部打线还是外部输出,
有了这个硬件上 ...
You can get 32.768 crystal   X32K/2*N onto a pin, on parts with T11, via T11CLKO
  • 打卡总天数:3
发表于 2024-8-21 10:16:30 | 显示全部楼层
{:5_332:},发现了,最新的8H2K支持T11定时器,这样就可以完美解决
GMT+8, 2025-11-3 04:17 , Processed in 0.135948 second(s), 89 queries .
