查看: 220|回复: 0
85-内部148K字节SRAM读写测试,STC32G144K246实验箱演示程序
发表于 2026-7-3 17:19:21 | 显示全部楼层 |阅读模式
主程序main.C代码如下(汇编版本在附件中):
读取芯片SRAM,通过串口1(115200,N,8,1)打印结果.
项目设置"Target"页面"External Memory"-"RAM", Start:0x10000, Size:0x20000.
下载时, 默认时钟 48MHz (用户可自行修改频率).
#include "..\comm\STC32G144K246.h"
#define MAIN_Fosc       48000000UL
#define Baudrate        115200L
#define TM              (65536 -(MAIN_Fosc/Baudrate/4))
#define PrintUart       1        //1:printf 使用 UART1; 2:printf 使用 UART2
void UartInit(void)
#if(PrintUart == 1)
    P_SW1 &= 0x3f;
    P_SW1 |= 0x00;      //UART1 switch to, 0x00: P3.0 P3.1, 0x40: P3.6 P3.7, 0x80: P1.6 P1.7, 0xC0: P4.3 P4.4
        SCON = (SCON & 0x3f) | 0x40;
        T1x12 = 1;          //定时器时钟1T模式
        S1BRT = 0;          //串口1选择定时器1为波特率发生器
        TL1  = TM;
        TH1  = TM>>8;
        TR1 = 1;                                //定时器1开始计时
//        SCON = (SCON & 0x3f) | 0x40;
//        T2L  = TM;
//        T2H  = TM>>8;
//        AUXR |= 0x15;   //串口1选择定时器2为波特率发生器
#else
        S2_S = 1;       //UART2 switch to: 0: P1.0 P1.1,  1: P4.6 P4.7
        S2CON = (S2CON & 0x3f) | 0x40;
        T2L  = TM;
        T2H  = TM>>8;
        AUXR |= 0x14;              //定时器2时钟1T模式,开始计时
#endif
#if(PrintUart == 1)
        SBUF = dat;
        while(TI==0);
        TI = 0;
#else
        S2BUF  = dat;
        while(S2TI == 0);
        S2TI = 0;    //Clear Tx flag
#endif
char putchar(char c)
        UartPutc(c);
        return c;
long index;
#define EDATA_LEN       16074L
#define XDATA1_LEN      65536L
#define XDATA2_LEN      65536L
#define XDATA3_LEN      4096L
unsigned char edata eRAM[EDATA_LEN];        //0000H~3FFFH
unsigned char xdata xRAM1[XDATA1_LEN];      //01:0000H~01:FFFFH
unsigned char far xRAM2[XDATA2_LEN] _at_ 0x020000;  //02:0000H~02:FFFFH
unsigned char far xRAM3[XDATA3_LEN] _at_ 0x030000;  //03:0000H~03:0FFFH
    EAXFR = 1; //扩展寄存器(XFR)访问使能
    CKCON = 0; //提高访问XRAM速度
    P3M1 = 0x00;   P3M0 = 0x02;   //设置为准双向口,P31推挽输出
        UartInit();
        printf("SRAM Test Start.\r\n");
        for(index=0;index<XDATA1_LEN;index++)
        if(index < EDATA_LEN)
            eRAM[index] = (unsigned char)index;
            if(eRAM[index] != (unsigned char)index) printf("Err eRAM[%02u]=0x%02X\r\n", (unsigned int)index, eRAM[index]);
//            printf("eRAM[%02u]=0x%02X  ", (unsigned int)index, eRAM[index]);
        if(index < XDATA1_LEN)
            xRAM1[index] = (unsigned char)index;
            if(xRAM1[index] != (unsigned char)index) printf("Err xRAM1[%02u]=0x%02X\r\n", (unsigned int)index, xRAM1[index]);
//            printf("xRAM1[%02u]=0x%02X  ", (unsigned int)index, xRAM1[index]);
        if(index < XDATA2_LEN)
            xRAM2[index] = (unsigned char)index;
            if(xRAM2[index] != (unsigned char)index) printf("Err xRAM2[%02u]=0x%02X\r\n", (unsigned int)index, xRAM2[index]);
//            printf("xRAM2[%02u]=0x%02X  ", (unsigned int)index, xRAM2[index]);
        if(index < XDATA3_LEN)
            xRAM3[index] = (unsigned char)index;
            if(xRAM3[index] != (unsigned char)index) printf("Err xRAM3[%02u]=0x%02X\r\n", (unsigned int)index, xRAM3[index]);
//            printf("xRAM3[%02u]=0x%02X", (unsigned int)index, xRAM3[index]);
//        printf("\r\n");
        printf("SRAM Test End.\r\n");
        while(1);
85-内部148K字节SRAM读写测试.zip (9.3 KB, 下载次数: 68)
GMT+8, 2026-11-8 01:40 , Processed in 0.068792 second(s), 44 queries .
