36.4-LCD128x64显示图形文字-ST7920-IO口模拟M6800并行接口,AI8051U实验箱演示程序
主程序main.C代码如下(汇编版本在附件中):
本例程基于AI8051U为主控芯片的实验箱9.6版本进行编写测试。
128*64的LCD显示程序
显示图形,汉字,英文,数字
下载时, 选择时钟 12MHz (用户可自行修改频率).
#include "../comm/AI8051U.h"
#include "stdio.h"
typedef unsigned char u8;
typedef unsigned int u16;
typedef unsigned long u32;
#define MAIN_Fosc 12000000UL
sbit LCD_RS = P4^5; //定义引脚
sbit LCD_RW = P3^6; //9.5版本之前实验箱需要将P42与P44对调才能正常使用
sbit LCD_E = P3^7;
//sbit PSB = P3^5; //PSB脚为12864的串、并通讯功能切换,我们使用8位并行接口,PSB=1
sbit LCD_RESET = P4^7; // 17---RESET L-->Enable
#define LCD_Data P2
#define Busy 0x80 //用于检测LCD状态字中的Busy标识
u8 code uctech[] = {"深圳国芯人工智能"};
u8 code net[] = {" www.stcai.com "};
u8 code mcu[] = {"专业设计51单片机"};
u8 code qq[] = {"AI8051U LQFP48 "};
//128*64点阵图形数据
u8 code gImage_gxw[1024] = { /* 0X10,0X01,0X00,0X80,0X00,0X40, */
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x3F,0x03,0xF0,0x3F,0x03,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x21,0x02,0x10,0x21,0x02,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x21,0x02,0x10,0x21,0x02,0x10,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x7F,0xF0,
0x00,0x21,0x02,0x10,0x21,0x02,0x10,0x01,0xFF,0xF0,0x41,0x00,0x7F,0xC0,0x00,0x00,
0x00,0x21,0x02,0x10,0x21,0x02,0x10,0x01,0x08,0x10,0x41,0x00,0x40,0x40,0x00,0x00,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF9,0x1F,0x90,0x41,0x00,0x7F,0xC0,0x00,0x00,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF9,0x31,0x10,0x7F,0xF0,0x40,0x41,0xFF,0xFC,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x19,0x4A,0x10,0x40,0x00,0x40,0x40,0x02,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x19,0x04,0x10,0x40,0x00,0x7F,0xC0,0x02,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x19,0x1B,0x10,0x40,0x00,0x11,0x00,0x22,0x20,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x19,0xE0,0xF0,0x7F,0x81,0x11,0x10,0x22,0x10,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x19,0x0C,0x10,0x40,0x80,0x91,0x10,0x42,0x08,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x19,0x02,0x10,0x40,0x80,0x51,0x20,0x82,0x04,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x19,0x18,0x10,0x40,0x80,0x51,0x41,0x02,0x04,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x19,0x06,0x10,0x80,0x80,0x11,0x00,0x0A,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x19,0xFF,0xF0,0x80,0x83,0xFF,0xF8,0x04,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x19,0x00,0x11,0x00,0x80,0x00,0x00,0x00,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x63,0x07,0x87,0x83,0xCF,0xC1,0x8C,0xD8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x67,0x83,0x0C,0xC6,0x6C,0x03,0x8C,0xD8,0x00,0x00,0x00,0x00,0x00,0x3E,0x00,0x00,
0x6C,0xC3,0x0C,0xC6,0xEC,0x0F,0x8C,0xD8,0x00,0x3C,0x00,0x00,0x00,0xFF,0x80,0x00,
0x6C,0xC3,0x0E,0xC6,0xEC,0x01,0x8C,0xD8,0x00,0xFF,0x80,0x00,0x03,0xFF,0xE0,0x00,
0x6C,0xC3,0x07,0x86,0x6F,0x81,0x8C,0xD8,0x03,0xFF,0xE0,0x00,0x07,0xFF,0xF0,0x00,
0x6F,0xC3,0x0D,0xC7,0x60,0xC1,0x8C,0xD8,0x07,0x80,0xF0,0x00,0x0F,0xFF,0xF8,0x00,
0x6C,0xC3,0x0C,0xC7,0x60,0xC1,0x8C,0xD8,0x0E,0x18,0x38,0x00,0x1F,0xFF,0xFC,0x00,
0x6C,0xC3,0x0C,0xC6,0x61,0x81,0x8C,0xD8,0x1C,0x18,0x1C,0x00,0x1F,0xFF,0xFC,0x00,
0x6C,0xC7,0x87,0x83,0xCF,0x01,0x87,0x98,0x38,0x18,0x0E,0x00,0x3F,0xFF,0xFE,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x30,0x18,0x06,0x00,0x3F,0xFF,0xFE,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x70,0x18,0x07,0x00,0x7C,0x3E,0x1F,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x60,0x18,0x03,0x00,0x7C,0x3E,0x1F,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x60,0x18,0x03,0x00,0x7E,0x7F,0x3F,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0xF0,0x18,0x07,0x80,0x7F,0xFF,0xFF,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0xF8,0x1F,0xCF,0x80,0x7F,0xFF,0xFF,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0xF0,0x00,0x07,0x80,0x7F,0xFF,0xFF,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x60,0x00,0x03,0x00,0x7F,0x80,0xFF,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x70,0x00,0x07,0x00,0x3F,0x80,0xFE,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x30,0x00,0x06,0x00,0x3F,0xC1,0xFE,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x38,0x00,0x0E,0x00,0x1F,0xE3,0xFC,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x1C,0x00,0x1C,0x00,0x0F,0xFF,0xF8,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x0E,0x18,0x38,0x00,0x07,0xFF,0xF0,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x07,0xBC,0xF0,0x00,0x03,0xFF,0xE0,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x03,0xFF,0xE0,0x00,0x01,0xFF,0xC0,0x00,
0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x00,0xFF,0x80,0x00,0x00,0x3E,0x00,0x00,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x3C,0x00,0x00,0x00,0x00,0x00,0x00,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
void delay_ms(u16 ms);
void WriteDataLCD(u8 WDLCD);
void WriteCommandLCD(u8 WCLCD,u8 BuysC);
u8 ReadDataLCD(void);
u8 ReadStatusLCD(void);
void LCDInit(void);
void LCDClear(void);
void LCDFlash(void);
void DisplayOneChar(u8 X, u8 Y, u8 DData);
void DisplayListChar(u8 X, u8 Y, u8 code *DData);
void DisplayImage (u8 code *DData);
EAXSFR(); //扩展寄存器(XFR)访问使能
CKCON = 0; //提高访问XRAM速度
P3M1 = 0x00; P3M0 = 0xc0; //设置为准双向口
P4M1 = 0x00; P4M0 = 0xa0; //设置为准双向口
delay_ms(100); //启动等待,等LCD讲入工作状态
LCDInit(); //LCM初始化
delay_ms(5); //延时片刻(可不要)
LCDClear();
DisplayImage(gImage_gxw);//显示图形
delay_ms(3000);
LCDClear();
DisplayListChar(0,1,uctech); //显示字库中的中文数字
DisplayListChar(0,2,net); //显示字库中的中文数字
DisplayListChar(0,3,mcu); //显示字库中的中文
DisplayListChar(0,4,qq); //显示字库中的中文数字
delay_ms(3000);
// 函数: void delay_ms(u8 ms)
// 描述: 延时函数。
// 版本: VER1.0
// 日期: 2013-4-1
// 备注:
u16 i;
do{
i = MAIN_Fosc / 6000;
while(--i);
}while(--ms);
void LCD_delay(void)
NOP(30); //电压降低,IO口翻转速度变慢,驱动信号需要增加延时时间
NOP(30);
//写数据
ReadStatusLCD(); //检测忙
LCD_RS = 1;
LCD_delay();
LCD_RW = 0;
LCD_Data = WDLCD;
LCD_delay();
LCD_E = 1;
LCD_delay();
LCD_E = 0;
//写指令
void WriteCommandLCD(u8 WCLCD,u8 BuysC) //BuysC为0时忽略忙检测
if (BuysC) ReadStatusLCD(); //根据需要检测忙
LCD_RS = 0;
LCD_delay();
LCD_RW = 0;
LCD_Data = WCLCD;
LCD_delay();
LCD_E = 1;
LCD_delay();
LCD_E = 0;
//读状态
LCD_Data = 0xFF;
LCD_RS = 0;
LCD_delay();
LCD_RW = 1;
LCD_delay();
LCD_E = 1;
LCD_delay();
while (LCD_Data & Busy); //检测忙信号
LCD_E = 0;
return(LCD_Data);
void LCDInit(void) //LCM初始化
// PSB = 1; //并口
// PSB = 0; //SPI口
delay_ms(10);
LCD_RESET = 0;
delay_ms(10);
LCD_RESET = 1;
delay_ms(100);
WriteCommandLCD(0x30,1); //显示模式设置,开始要求每次检测忙信号
WriteCommandLCD(0x01,1); //显示清屏
WriteCommandLCD(0x06,1); // 显示光标移动设置
WriteCommandLCD(0x0C,1); // 显示开及光标设置
void LCDClear(void) //清屏
WriteCommandLCD(0x34,1); // 显示光标移动设置
WriteCommandLCD(0x30,1); // 显示开及光标设置
//按指定位置显示一串字符
u8 ListLength,X2;
ListLength = 0;
X2 = X;
if(Y < 1) Y=1;
if(Y > 4) Y=4;
X &= 0x0F; //限制X不能大于16,Y在1-4之内
switch(Y)
case 1: X2 |= 0X80; break; //根据行数来选择相应地址
case 2: X2 |= 0X90; break;
case 3: X2 |= 0X88; break;
case 4: X2 |= 0X98; break;
WriteCommandLCD(X2, 1); //发送地址码
while (DData[ListLength] >= 0x20) //若到达字串尾则退出
if (X <= 0x0F) //X坐标应小于0xF
WriteDataLCD(DData[ListLength]); //
ListLength++;
X++;
//图形显示122*32
u8 x,y,i;
unsigned int tmp=0;
for(i=0;i<9;) //分两屏,上半屏和下半屏,因为起始地址不同,需要分开
for(x=0;x<32;x++) //32行
WriteCommandLCD((u8)(0x80+x),1);//列地址
WriteCommandLCD((u8)(0x80+i),1); //行地址,下半屏,即第三行地址0X88
for(y=0;y<16;y++)
WriteDataLCD(DData[tmp+y]);//读取数据写入LCD
tmp+=16;
i+=8;
WriteCommandLCD(0x36,1); //扩充功能设定
36.4-LCD128x64显示图形文字-ST7920-IO口模拟M6800并行接口.zip
(8.79 KB, 下载次数: 75)
