查看: 192|回复: 0
36.3-LCD1602显示程序-硬件M6800并行接口+DMA刷新,AI8051U实验箱演示程序
发表于 2026-6-30 14:10:27 | 显示全部楼层 |阅读模式
主程序main.C代码如下(汇编版本在附件中):
请先别修改程序, 直接下载"LCD1602.hex"测试, 下载时选择主频40MHz.
LCM1602字符液晶模块,8位数据,全部由LCM DMA驱动,节省CPU时间(LCD1602用IO方式访问速度很慢!)。
本程序在AI8051U实验箱上验证,使用3.3V的LCD1602模块。
const u8  text1[] = {" LCD1602 8-DATA "};
const u8  text2[] = {" AI8051U-34K64  "};
const u8  text3[] = {"2024-10-22 21:29"};
const u8  text4[] = {" WWW.STCAI.com  "};
u16        LCM_TxCnt;                //LCM DMA触发发送次数, 一次16字节, 一共64次
bit        B_LCM_DMA_busy;        //LCM DMA忙标志, 1标志LCM-DMA忙,LCM DMA中断中清除此标志,使用LCM DMA前要确认此标志为0
bit        B_TxCmd;                //已发送命令标志
u8        xdata CmdTmp[2];        //命令缓冲
u8        xdata DisTmp1[16];        //第一行显示缓冲,将要显示的内容放在显存里,启动DMA即可.
u8        xdata DisTmp2[16];        //第二行显示缓冲,将要显示的内容放在显存里,启动DMA即可.
/*************        Pin define        *****************************************************/
sfr                LCD_DATA = 0xa0;        //P0--0x80,  P1--0x90,  P2--0xa0,  P3--0xb0
sbit        LCD_B7  = P2^7;        //Pin 14        B3--Pin 10                LED+ -- Pin 15
                                                //Pin 13        B2--Pin 9                LED- -- Pin 16
                                                //Pin 12        B1--Pin 8                Vo   -- Pin 3
                                                //Pin 11        B0--Pin 7                VDD  -- Pin 2                VSS -- Pin 1
sbit        LCD_ENA        = P3^7;        //Pin 6
sbit        LCD_RW        = P3^6;        //Pin 5        //LCD_RS   R/W   DB7--DB0        FOUNCTION
sbit        LCD_RS        = P4^5;        //Pin 4        //        0                0          INPUT      write the command to LCD model
        //        0                1     OUTPUT     read BF and AC pointer from LCD model
        //        1                0     INPUT      write the data to LCD  model
        //        1                1     OUTPUT     read the data from LCD model
                 HD44780U    LCD_MODUL DRIVE PROGRAMME
total 2 lines, 16x2= 32
first line address:  0~15
second line address: 64~79
total 2 lines, 20x2= 40
first line address:  0~19
second line address: 64~83
total 2 lines, 40x2= 80
first line address:  0~39
second line address: 64~103
#define C_CLEAR                        0x01                //clear LCD
#define C_HOME                         0x02                //cursor go home
#define C_CUR_L                        0x04                //cursor shift left after input
#define C_RIGHT                        0x05                //picture shift right after input
#define C_CUR_R                        0x06                //cursor shift right after input
#define C_LEFT                         0x07                //picture shift left after input
#define C_OFF                          0x08                //turn off LCD
#define C_ON                           0x0C                //turn on  LCD
#define C_FLASH                        0x0D                //turn on  LCD, flash
#define C_CURSOR                0x0E                //turn on  LCD and cursor
#define C_FLASH_ALL                0x0F                //turn on  LCD and cursor, flash
#define C_CURSOR_LEFT        0x10                //single cursor shift left
#define C_CURSOR_RIGHT        0x10                //single cursor shift right
#define C_PICTURE_LEFT        0x10                //single picture shift left
#define C_PICTURE_RIGHT        0x10                //single picture shift right
#define C_BIT8                        0x30                //set the data is 8 bits
#define C_BIT4                        0x20                //set the data is 8 bits
#define C_L1DOT7                0x30                //8 bits,one line 5*7  dots
#define C_L1DOT10                0x34                //8 bits,one line 5*10 dots
#define C_8bitL2DOT7        0x38                //8 bits,tow lines 5*7 dots
#define C_4bitL2DOT7        0x28                //4 bits,tow lines 5*7 dots
#define C_CGADDRESS0        0x40                //CGRAM address0 (addr=40H+x)
#define C_DDADDRESS0        0x80                //DDRAM address0 (addr=80H+x)
// 函数: void  delay_ms(u16 ms)
// 描述: 延时函数。
// 参数: ms,要延时的ms数, 1~65535ms. 自动适应主时钟.
// 版本: VER1.0
// 日期: 2013-4-1
// 备注:
     u16 i;
         do
                 i = MAIN_Fosc / 6000;
                while(--i)        ;
     }while(--ms);
void        LCD_DelayNop(void)
        NOP(27);        // 我测试的屏至少 调用返回6T+24个NOP @40MHz, 建议NOP至少个数=FOSC(MHz) * 0.75-6
void        CheckBusy(void)                //检测忙标志
        u16        i;
        LCD_RS = 0;                //读忙标志或AC指针
        LCD_RW = 1;
        LCD_DATA = 0xff;
        LCD_DelayNop();
        LCD_ENA = 1;
        for(i=0; i<10000; i++)                //忙检测 check the LCD busy or not. With time out. 我测试的屏至少6500@40MHz
                if(!LCD_B7)        break;
        LCD_ENA = 0;
void IniSendCMD(u8 cmd)                //write the command to LCD
        LCD_RS = 0;                //写命令
        LCD_RW = 0;
        LCD_DATA = cmd;
        LCD_DelayNop();
        LCD_ENA = 1;
        LCD_DelayNop();
        LCD_ENA = 0;
        LCD_DATA = 0xff;
        LCD_DelayNop();
void Write_CMD(u8 cmd)                //write the command to LCD
        CheckBusy();        //检测忙标志  check the LCD busy or not.
        LCD_RS = 0;                //写命令
        LCD_RW = 0;
        LCD_DATA = cmd;
        LCD_DelayNop();
        LCD_ENA = 1;
        LCD_DelayNop();
        LCD_ENA = 0;
        LCD_DATA = 0xff;
        LCD_DelayNop();
/*********        初始化函数        **************************/
void Initialize_LCD(void)                //intilize LCD, input none, output none
        P2n_standard(0xff);
        P3n_standard(Pin7+Pin6);
        P4n_standard(Pin5);
        delay_ms(1);
        LCD_ENA = 0;
        LCD_RS  = 0;
        LCD_RW  = 0;
        delay_ms(100);
        IniSendCMD(C_BIT8);                //set the data is 4 bits
        delay_ms(10);
        delay_ms(10);
        IniSendCMD(C_8bitL2DOT7);        //tow lines 5*7 dots
        delay_ms(6);
        Write_CMD(C_CLEAR);                //clear LCD RAM
        Write_CMD(C_CUR_R);                //Curror Shift Right
        Write_CMD(C_ON);                //turn on  LCD
//******************** LCD40 Module END ***************************
// 函数: void LCM_Config(void)
// 描述: LCM配置函数。ST7920 @540KHz,清屏指令典型时间为1.6ms,读忙信号0us, 写入、读出数据、命令72us. 本例子DMA刷新时间84ms @24MHz.
// 参数: none.
// 版本: V1.0, 2024-8-17
// 备注:
//LCMIFCFG  (7EFE50H)        TFT彩屏接口配置寄存器
#define        LCMIFIE                        (0<<7)        //TFT彩屏接口中断使能控制位(bit7), 1->允许中断,0->禁止
#define        LCMIFIP                        (0<<4)        //TFT彩屏接口中断优先级控制位(bit5~bit4), (最低)0~3(最高).
#define        LCMIFDPS                (0<<2)        //TFT彩屏接口数据脚选择位(bit3~bit2), D18_D8=0: 0或2->8位数据在P2, D18_D8=1: 0: P2-高字节, P0低字节, 2: P2-高字节,低字节P0[7:4] P4.7 P4.6 P4.3 P4.1.
#define        LCM_D16_D8                (0<<1)        //TFT彩屏接口数据宽度控制位(bit1), 0: 8位数据,1:16位数据
#define        LCM_M68_I80                1                //TFT彩屏接口数据模式选择位(bit0), 0: I8080模式,1:M6800模式
//LCMIFCFG2  (7EFE51H)        TFT彩屏接口配置寄存器2
#define        LCMIFCPS                (1<<5)        //TFT彩屏接口控制脚选择位(bit6~bit5), RS RD(E) WR(RW), 0->P4.5 P4.4 P4.2,1->P4.5 P3.7 P3.6, 2->P4.0 P4.4 P4.2, 3->P4.0 P3.7 P3.6
#define        LCMSETUPT                (4<<2)        //TFT彩屏接口数据建立时间控制位(bit4~bit2), 0~7, 对应1~8个LCMIF时钟, 对于6800模式就是E高电平时间, 至少20us.
#define        LCMHOLDT                3                //TFT彩屏接口数据保持时间控制位(bit1~bit0), 0~3, 对应1~4个LCMIF时钟
//LCMIFCR  (7EFE52H)        TFT彩屏接口控制寄存器
#define        ENLCMIF                        (1<<7)        //TFT彩屏接口使能控制位(bit7), 1->允许TFT彩屏接口功能, 0->禁止
#define        LCM_WRCMD                4                //TFT彩屏接口触发命令(bit2~bit0), 4->写命令
#define        LCM_WRDAT                5                //TFT彩屏接口触发命令(bit2~bit0), 5->写数据
#define        LCM_RDCMD                6                //TFT彩屏接口触发命令(bit2~bit0), 6->读命令/状态
#define        LCM_RDDAT                7                //TFT彩屏接口触发命令(bit2~bit0), 7->读数据
        LCMIFCFG  = LCMIFIE  | LCMIFIP   | LCMIFDPS | LCM_D16_D8 | LCM_M68_I80;
        LCMIFCFG2 = LCMIFCPS | LCMSETUPT | LCMHOLDT;        //RS:P45,E:P37,RW:P36; Setup Time,HOLD Time
        LCMIFSTA  = 0x00;        //TFT彩屏接口中断请求标志,软件清0
        LCMIFPSCR = (u8)(MAIN_Fosc/250000UL-1);        //TFT彩屏接口时钟预分频0~255, LCMIF时钟频率 = SYSclk/(LCMIFPSCR+1), LCD1602速度慢,最快250KHz
        LCMIFCR   = ENLCMIF;
// 函数: void DMA_Config(u8 xdata *pic)
// 描述: LCM DMA配置函数。
// 参数: *pic: 数据首地址.
// 备注:
//DMA_LCM_CR (7EfA71H)         LCM_DMA控制寄存器
#define                DMA_ENLCM        (1<<7)        // LCM DMA功能使能控制位,    bit7, 0:禁止LCM DMA功能,  1:允许LCM DMA功能。
#define                LCM_TRIGWC        (1<<6)        // LCM DMA触发写命令,bit6, 0:写0无效,          1:写1开始LCM DMA开始写命令。
#define                LCM_TRIGWD        (1<<5)        // LCM DMA触发写数据,bit5, 0:写0无效,          1:写1开始LCM DMA开始写数据。
#define                LCM_TRIGRC        (1<<4)        // LCM DMA触发读命令,bit4, 0:写0无效,          1:写1开始LCM DMA开始读命令。
#define                LCM_TRIGRD        (1<<3)        // LCM DMA触发读数据,bit3, 0:写0无效,          1:写1开始LCM DMA开始读数据。
#define                LCM_CLRFIFO        0                // 清除LCM DMA接收FIFO控制位,bit0, 0:写0无效,  1:写1复位FIFO指针。
//DMA_LCM_CFG         (7EfA70H)   LCM_DMA配置寄存器
#define                DMA_LCMIE        (1<<7)        // LCM DMA中断使能控制位,bit7, 0:禁止SPI DMA中断,     1:允许中断。
#define                DMA_LCMIP        (0<<2)        // LCM DMA中断优先级控制位,bit3~bit2, (最低)0~3(最高).
#define                DMA_LCMPTY        0                // LCM DMA数据总线访问优先级控制位,bit1~bit0, (最低)0~3(最高).
//DMA_LCM_STA  (7EfA72)         LCM_DMA状态寄存器
#define                LCM_TXOVW        (1<<1)        // LCM DMA数据覆盖标志位,bit1, 软件清0.
#define                DMA_LCMIF        1                // LCM DMA中断请求标志位,bit0, 软件清0.
void LCM_DMA_Trig(void)
        DMA_LCM_STA  = 0x00;
        DMA_LCM_CFG  = DMA_LCMIE | DMA_LCMIP | DMA_LCMPTY;;
        DMA_LCM_ITVH = 0;        //设置传输间隔时间(高8位),对应N+1个LCMIF时钟(1~65536个LCMIF时钟)
        DMA_LCM_ITVL = 9-1;        //设置传输间隔时间(低8位)
        B_TxCmd   = 0;                //已发送命令标志
        LCM_TxCnt = 0;                //LCM DMA触发发送次数, 一次16字节, 一共64次
        B_LCM_DMA_busy = 1;        //标志LCM-DMA忙,LCM DMA中断中清除此标志,使用LCM DMA前要确认此标志为0
        DMA_LCM_STA = DMA_LCMIF;        //软件触发LCM DMA中断,启动发送
// 函数: void LCMIF_DMA_ISR(void) interrupt USER_VECTOR//DMA_LCM_VECTOR
// 描述: LCM DMA中断函数。中断处理时间:2.3us @24MHz. 刷新时间:84ms @24MHz.
// 参数: none.
// 备注:
        if(DMA_LCM_STA & DMA_LCMIF)
                if(LCM_TxCnt >= 2)        //判断发送是否完毕
                        DMA_LCM_CR = 0;
                        B_LCM_DMA_busy = 0;                //清除LCM-DMA忙标志,LCM DMA中断中清除此标志,使用LCM DMA前要确认此标志为0
                else                //仍有数据要发送
                        if(!B_TxCmd)        //还没有发设置地址命令,则先发设置地址命令
                                B_TxCmd = 1;        //指示已发地址命令
                                if(LCM_TxCnt == 0)   //第一行地址设置命令
                                        LCD_RS = 0;                //写命令
                                        LCD_RW = 0;
                                        CmdTmp[0] = 0x80;        //第一行AC地址
                                else if(LCM_TxCnt == 1)   //第二行地址设置命令
                                        LCD_RS = 0;                //写命令
                                        LCD_RW = 0;
                                        CmdTmp[0] = 0x80 | 64;        //第二行AC地址
                                DMA_LCM_TXAH = (u8)((u16)CmdTmp >> 8);        //LCM DMA发送命令首地址
                                DMA_LCM_TXAL = (u8)CmdTmp;
                                DMA_LCM_AMTH = 0;                        //设置传输总字节数(高8位),        设置传输总字节数 = N+1
                                DMA_LCM_AMT  = 1-1;                        //设置传输总字节数(低8位).
                                DMA_LCM_CR   = DMA_ENLCM | LCM_TRIGWC;        //启动LCM DMA发送命令
                        else        //写数据
                                LCD_RS = 1;                //写显示数据
                                LCD_RW = 0;
                                B_TxCmd = 0;        //清除已发地址命令
                                if(LCM_TxCnt == 0)   //第一行显示缓冲地址
                                        DMA_LCM_TXAH = (u8)((u16)DisTmp1 >> 8);        //LCM DMA发送数据首地址
                                        DMA_LCM_TXAL = (u8)DisTmp1;
                                else //if(LCM_TxCnt == 1)   //第二行显示缓冲地址
                                        DMA_LCM_TXAH = (u8)((u16)DisTmp2 >> 8);        //LCM DMA发送数据首地址
                                        DMA_LCM_TXAL = (u8)DisTmp2;
                                DMA_LCM_AMT  = 16-1;                        //设置传输总字节数(低8位).
                                DMA_LCM_CR   = DMA_ENLCM | LCM_TRIGWD;        //启动LCM DMA发送数据
                                LCM_TxCnt++;                //发送行数+1
        DMA_LCM_STA = 0;
/*************** 主函数 *******************************/
        u8 i = 0;
        EAXSFR();        //扩展寄存器(XFR)访问使能
        WTST  = 0;        //设置程序指令延时参数,赋值为0可将CPU执行指令的速度设置为最快
        CKCON = 0;        //提高访问XRAM速度
        delay_ms(100);        //等待一下,等LCD讲入工作状态
        LCM_Config();
        Initialize_LCD();        //初始化LCD
                if(!B_LCM_DMA_busy)                //DMA空闲
                        for(i=0; i<16; i++)        //将要显示的文本装载到显存
                                DisTmp1 = text1;        //加载第一行显存
                                DisTmp2 = text2;        //加载第二行显存
                        LCM_DMA_Trig();                //启动DMA,显示文本
                delay_ms(2000);
                                DisTmp1 = text3;        //加载第一行显存
                                DisTmp2 = text4;        //加载第二行显存
                delay_ms(2000);
36.3-LCD1602显示程序-硬件M6800并行接口 DMA刷新.zip (88.91 KB, 下载次数: 88)
热线19952583534
www.STCAI.com
GMT+8, 2026-11-8 02:16 , Processed in 0.067819 second(s), 42 queries .
