81-播放WAV-8K采样率-8bit采样-PT8211(DAC),STC8H8K64U实验箱演示程序, STC8H2K32U, STC8H2K12U, STC8H
主程序main.C代码如下(汇编版本在附件中):
#define MAIN_Fosc 24000000L //定义主时钟
#include "STC8Hxxx.h"
#include "music-8bit-8K-wave.h"
使用STC8H系列MCU外接立体声DAC PT8211(TM8211) 播放8位WAVE语音.
语音参数: 8k采样 单声道, 码率64kb/s, 时长6.4秒.
sbit P_TM8211_BCK = P0^2; //PIN1--BCK 8--RCH 4--GND
sbit P_TM8211_WS = P0^1; //PIN2--WS 7--NC 5--VDD
sbit P_TM8211_DIN = P0^0; //PIN3--DIN 6--LCH
u16 play_lenth;
u16 LastSample;
u16 PlayCnt;
u8 code *MusicPoint;
bit B_Play;
u8 DAC_Cnt;
void LoadMusic(void);
u8 Timer0_Config(u16 reload); //reload是重装值, 返回0正确, 返回1装载值过大错误.
/************* 外部函数和变量声明 *****************/
/******************** 主函数**************************/
P0n_standard(0xff); //设置为准双向口
P1n_standard(0xff); //设置为准双向口
P2n_standard(0xff); //设置为准双向口
P3n_standard(0xff); //设置为准双向口
P4n_standard(0xff); //设置为准双向口
P5n_standard(0xff); //设置为准双向口
Timer0_Config(MAIN_Fosc / 8000); //t=0: reload值是主时钟周期数, (中断频率, 8000次/秒)
EA = 1; //允许全局中断
if(!B_Play) LoadMusic();
NOP(10);
// 函数: void LoadWave(void)
// 描述: 装载一段wav
// 参数: none.
// 版本: VER1.0
// 日期: 2014-8-15
// 备注:
MusicPoint = Music;
play_lenth = ((u16)MusicPoint[41] << 8) + MusicPoint[40];
MusicPoint += 44;
PlayCnt = 0;
B_Play = 1;
void TM8211_Wbyte(u8 dat)
ACC = dat;
P_TM8211_DIN = ACC7; NOP(1); P_TM8211_BCK = 1; NOP(1); P_TM8211_BCK = 0; //6*8+7=55T
P_TM8211_DIN = ACC6; NOP(1); P_TM8211_BCK = 1; NOP(1); P_TM8211_BCK = 0;
P_TM8211_DIN = ACC5; NOP(1); P_TM8211_BCK = 1; NOP(1); P_TM8211_BCK = 0;
P_TM8211_DIN = ACC4; NOP(1); P_TM8211_BCK = 1; NOP(1); P_TM8211_BCK = 0;
P_TM8211_DIN = ACC3; NOP(1); P_TM8211_BCK = 1; NOP(1); P_TM8211_BCK = 0;
P_TM8211_DIN = ACC2; NOP(1); P_TM8211_BCK = 1; NOP(1); P_TM8211_BCK = 0;
P_TM8211_DIN = ACC1; NOP(1); P_TM8211_BCK = 1; NOP(1); P_TM8211_BCK = 0;
P_TM8211_DIN = ACC0; NOP(1); P_TM8211_BCK = 1; NOP(1); P_TM8211_BCK = 0;
// 函数:u8 Timer0_Config(u8 t, u32 reload)
// 描述: timer0初始化函数.
// 参数: reload: 重装值.
// 返回: 0: 初始化正确, 1: 重装值过大, 初始化错误.
// 版本: V1.0, 2018-12-20
u8 Timer0_Config(u16 reload) //reload是重装值
TR0 = 0; //停止计数
if(reload >= (65536UL * 12)) return 1; //值过大, 返回错误
if(reload < 65536UL) AUXR |= 0x80; //1T mode
AUXR &= ~0x80; //12T mode
reload = reload / 12;
reload = 65536UL - reload;
TH0 = (u8)(reload >> 8);
TL0 = (u8)(reload);
ET0 = 1; //允许中断
// PT0 = 1; //高优先级中断
TMOD = (TMOD & ~0x03) | 0; //工作模式, 0: 16位自动重装, 1: 16位定时/计数, 2: 8位自动重装, 3: 16位自动重装, 不可屏蔽中断
// TMOD |= 0x04; //对外计数或分频
// INT_CLKO |= 0x01; //输出时钟
TR0 = 1; //开始运行
return 0;
// 函数: void timer0_int (void) interrupt TIMER0_VECTOR
// 描述: timer0中断函数.
// 参数: none.
void timer0_ISR (void) interrupt TIMER0_VECTOR
u16 j;
if(B_Play)
j = ((u16)*MusicPoint << 8) + 32768; //8位无符号wav数据转16位有符号整数
TM8211_Wbyte((u8)(j >> 8)); //输出DAC
TM8211_Wbyte((u8)j);
P_TM8211_WS = 0;
NOP(2); //另一个声道, 如果没有数据, 则两个声道输出相同(单声道)
P_TM8211_WS = 1;
MusicPoint++; //指向下一个数据
if(++PlayCnt >= play_lenth) B_Play = 0;
81-播放WAV-8K采样率-8bit采样-PT8211(DAC).zip
(172.44 KB, 下载次数: 70)
