查看: 278|回复: 1
67-老梁示波器-CDC虚拟显示,STC8H8K64U实验箱演示程序, STC8H2K32U, STC8H2K12U, STC
发表于 2026-6-30 13:09:51 | 显示全部楼层 |阅读模式
67-老梁示波器-CDC虚拟显示,STC8H8K64U实验箱演示程序, STC8H2K32U, STC8H2K12U, STC8H
主程序main.C代码如下(汇编版本在附件中):
#include        "config.h"
//#include "stc.h"
#include "uart.h"
#include "usb.h"
BOOL RxFlag;
BYTE RxCount;
BYTE xdata RxBuffer[64];
BYTE xdata TxBuffer[1024];
void uart_init()
    RxFlag = 0;
    RxCount = 0;
void uart_send(int size)
    BYTE cnt;
    int addr;
    IE2 &= ~EUSB;
    usb_write_reg(INDEX, 1);
    addr = 0;
    do
        cnt = size > 64 ? 64 : size;
        while (usb_read_reg(INCSR1) & INIPRDY);
        usb_bulk_intr_in(&TxBuffer[addr], cnt, 1);
        addr += cnt;
        size -= cnt;
    } while (cnt >= 64);
    IE2 |= EUSB;
void uart_recv_done()
    IE2 &= ~EUSB;
    RxFlag = 0;
    usb_write_reg(OUTCSR1, 0);
    IE2 |= EUSB;
67-老梁示波器-CDC虚拟显示.zip (936.41 KB, 下载次数: 74)
热线19952583534
www.STCAI.com
 楼主| 发表于 2026-7-7 10:41:26 | 显示全部楼层
#include "config.h"
#include "usb.h"
#include "usb_req_std.h"
#include "usb_req_class.h"
#include "usb_req_vendor.h"
#include "util.h"
#include "uart.h"
BYTE DeviceState;
SETUP Setup;
EPSTATE Ep0State;
BYTE InEpState;
BYTE OutEpState;
void usb_init()
        P3M0 &= ~0x03;        //P3.0 P3.1设置为高阻输入
        P3M1 |= 0x03;
        IRC48MCR = 0x80;        //开启USB时钟
        while (!(IRC48MCR & 0x01));        //等待USB时钟稳定
    USBCLK = 0x00;
    USBCON = 0x90;
    usb_write_reg(FADDR, 0x00);
    usb_write_reg(POWER, 0x08);
    usb_write_reg(INTRIN1E, 0x3f);
    usb_write_reg(INTROUT1E, 0x3f);
    usb_write_reg(INTRUSBE, 0x07);
    usb_write_reg(POWER, 0x00);
    DeviceState = DEVSTATE_DEFAULT;
    Ep0State.bState = EPSTATE_IDLE;
    InEpState = 0x00;
    OutEpState = 0x00;
    IE2 |= EUSB;
BYTE usb_read_reg(BYTE addr)
        BYTE dat;
        while (USBADR & 0x80);
        USBADR = addr | 0x80;
        dat = USBDAT;
        return dat;
void usb_write_reg(BYTE addr, BYTE dat)
        USBADR = addr & 0x7f;
        USBDAT = dat;
BYTE usb_read_fifo(BYTE fifo, BYTE *pdat)
    BYTE cnt;
    BYTE ret;
    ret = cnt = usb_read_reg(COUNT0);
    while (cnt--)
            *pdat++ = usb_read_reg(fifo);
    return ret;
void usb_write_fifo(BYTE fifo, BYTE *pdat, BYTE cnt) reentrant
        while (cnt--)
        usb_write_reg(fifo, *pdat++);
void usb_isr() interrupt 25
    BYTE intrusb;
    BYTE intrin;
    BYTE introut;
    intrusb = usb_read_reg(INTRUSB);
    intrin = usb_read_reg(INTRIN1);
    introut = usb_read_reg(INTROUT1);
    if (intrusb & RSUIF) usb_resume();
    if (intrusb & RSTIF) usb_reset();
    if (intrin & EP0IF) usb_setup();
#ifdef EN_EP1IN
    if (intrin & EP1INIF) usb_in_ep1();
#endif
#ifdef EN_EP2IN
    if (intrin & EP2INIF) usb_in_ep2();
#endif
#ifdef EN_EP3IN
    if (intrin & EP3INIF) usb_in_ep3();
#endif
#ifdef EN_EP4IN
    if (intrin & EP4INIF) usb_in_ep4();
#endif
#ifdef EN_EP5IN
    if (intrin & EP5INIF) usb_in_ep5();
#endif
#ifdef EN_EP1OUT
    if (introut & EP1OUTIF) usb_out_ep1();
#endif
#ifdef EN_EP2OUT
    if (introut & EP2OUTIF) usb_out_ep2();
#endif
#ifdef EN_EP3OUT
    if (introut & EP3OUTIF) usb_out_ep3();
#endif
#ifdef EN_EP4OUT
    if (introut & EP4OUTIF) usb_out_ep4();
#endif
#ifdef EN_EP5OUT
    if (introut & EP5OUTIF) usb_out_ep5();
#endif
    if (intrusb & SUSIF) usb_suspend();
void usb_resume()
void usb_reset()
#ifdef EN_EP1IN
    usb_write_reg(INCSR1, INCLRDT | INFLUSH);
#endif
#ifdef EN_EP2IN
    usb_write_reg(INDEX, 2);
#endif
#ifdef EN_EP3IN
    usb_write_reg(INDEX, 3);
#endif
#ifdef EN_EP4IN
    usb_write_reg(INDEX, 4);
#endif
#ifdef EN_EP5IN
    usb_write_reg(INDEX, 5);
#endif
#ifdef EN_EP1OUT
    usb_write_reg(OUTCSR1, OUTCLRDT | OUTFLUSH);
#endif
#ifdef EN_EP2OUT
#endif
#ifdef EN_EP3OUT
#endif
#ifdef EN_EP4OUT
#endif
#ifdef EN_EP5OUT
#endif
    usb_write_reg(INDEX, 0);
void usb_suspend()
void usb_setup()
    BYTE csr;
    csr = usb_read_reg(CSR0);
    if (csr & STSTL)
        usb_write_reg(CSR0, csr & ~SDSTL);
    if (csr & SUEND)
        usb_write_reg(CSR0, csr & ~SSUEND);
    switch (Ep0State.bState)
    case EPSTATE_IDLE:
        if (csr & OPRDY)
            usb_read_fifo(FIFO0, (BYTE *)&Setup);
            Setup.wLength = reverse2(Setup.wLength);
            switch (Setup.bmRequestType & REQUEST_MASK)
            case STANDARD_REQUEST:
                usb_req_std();
                break;
            case CLASS_REQUEST:
                usb_req_class();
                break;
            case VENDOR_REQUEST:
                usb_req_vendor();
                break;
            default:
                usb_setup_stall();
                return;
        break;
    case EPSTATE_DATAIN:
        usb_ctrl_in();
        break;
    case EPSTATE_DATAOUT:
        usb_ctrl_out();
        break;
void usb_setup_stall()
    Ep0State.bState = EPSTATE_STALL;
    usb_write_reg(CSR0, SOPRDY | SDSTL);
void usb_setup_in()
    Ep0State.bState = EPSTATE_DATAIN;
    usb_write_reg(CSR0, SOPRDY);
    usb_ctrl_in();
void usb_setup_out()
    Ep0State.bState = EPSTATE_DATAOUT;
void usb_setup_status()
    usb_write_reg(CSR0, SOPRDY | DATEND);
void usb_ctrl_in()
    BYTE csr;
    BYTE cnt;
    if (csr & IPRDY) return;
    cnt = Ep0State.wSize > EP0_SIZE ? EP0_SIZE : Ep0State.wSize;
    usb_write_fifo(FIFO0, Ep0State.pData, cnt);
    Ep0State.wSize -= cnt;
    Ep0State.pData += cnt;
    if (Ep0State.wSize == 0)
        usb_write_reg(CSR0, IPRDY | DATEND);
        usb_write_reg(CSR0, IPRDY);
void usb_ctrl_out()
    BYTE csr;
    BYTE cnt;
    if (!(csr & OPRDY)) return;
    cnt = usb_read_fifo(FIFO0, Ep0State.pData);
    usb_uart_settings();
void usb_bulk_intr_in(BYTE *pData, BYTE bSize, BYTE ep)
    usb_write_fifo((BYTE)(FIFO0 + ep), pData, bSize);
    usb_write_reg(INCSR1, INIPRDY);
#ifdef EN_EP1IN
void usb_in_ep1()
    BYTE csr;
    csr = usb_read_reg(INCSR1);
    if (csr & INSTSTL)
        usb_write_reg(INCSR1, INCLRDT);
    if (csr & INUNDRUN)
        usb_write_reg(INCSR1, 0);
#endif
#ifdef EN_EP2IN
void usb_in_ep2()
    BYTE csr;
    if (csr & INSTSTL)
    if (csr & INUNDRUN)
#endif
#ifdef EN_EP3IN
void usb_in_ep3()
    BYTE csr;
    if (csr & INSTSTL)
    if (csr & INUNDRUN)
#endif
#ifdef EN_EP4IN
void usb_in_ep4()
    BYTE csr;
    if (csr & INSTSTL)
    if (csr & INUNDRUN)
#endif
#ifdef EN_EP5IN
void usb_in_ep5()
    BYTE csr;
    if (csr & INSTSTL)
    if (csr & INUNDRUN)
#endif
#ifdef EN_EP1OUT
void usb_out_ep1()
    BYTE csr;
    csr = usb_read_reg(OUTCSR1);
    if (csr & OUTSTSTL)
        usb_write_reg(OUTCSR1, OUTCLRDT);
    if (csr & OUTOPRDY)
        RxCount = usb_read_fifo(FIFO1, RxBuffer);
        RxFlag = 1;
#endif
#ifdef EN_EP2OUT
void usb_out_ep2()
    BYTE csr;
    if (csr & OUTSTSTL)
    if (csr & OUTOPRDY)
        usb_bulk_intr_out(Ep2OutBuffer, 2);
#endif
#ifdef EN_EP3OUT
void usb_out_ep3()
    BYTE csr;
    if (csr & OUTSTSTL)
    if (csr & OUTOPRDY)
        usb_bulk_intr_out(Ep3OutBuffer, 3);
#endif
#ifdef EN_EP4OUT
void usb_out_ep4()
    BYTE csr;
    if (csr & OUTSTSTL)
    if (csr & OUTOPRDY)
        usb_bulk_intr_out(Ep4OutBuffer, 4);
#endif
#ifdef EN_EP5OUT
void usb_out_ep5()
    BYTE csr;
    if (csr & OUTSTSTL)
    if (csr & OUTOPRDY)
        usb_bulk_intr_out(Ep5OutBuffer, 5);
#endif
67-老梁示波器-CDC虚拟显示.zip (936.41 KB, 下载次数: 81)
热线19952583534
www.STCAI.com
GMT+8, 2026-11-8 01:44 , Processed in 0.068906 second(s), 46 queries .
