59-LIN总线主机收发测试-USART2,STC32G12K128实验箱演示程序,STC32G8K64,STC32CL8K64
主程序main.C代码如下(汇编版本在附件中):
本例程基于STC32G为主控芯片的实验箱进行编写测试。
USART类型Lin主机总线收发测试用例,默认通信脚:P4.6 P4.7.
按一下P32口按键, 主机发送完整一帧数据.
按一下P33口按键, 主机发送帧头并获取从机应答数据(合并成一串完整的帧).
默认传输速率:9600波特率, 用户可自行修改.
下载时, 默认时钟 24MHz (用户可自行修改频率).
#include "..\comm\STC32G.h"
#include "stdio.h"
typedef unsigned char u8;
typedef unsigned int u16;
typedef unsigned long u32;
#define MAIN_Fosc 24000000UL
#define Baudrate 9600UL
#define TM (65536UL -(MAIN_Fosc/Baudrate/4))
sbit SLP_N = P5^0; //0: Sleep
#define FRAME_LEN 8 //数据长度: 8 字节
#define UART2_BUF_LENGTH 64
u8 Lin_ID;
u8 TX_BUF[8];
bit B_1ms; //1ms标志
u16 msecond;
bit B_TX2_Busy; //发送忙标志
u8 TX2_Cnt; //发送计数
u8 RX2_Cnt; //接收计数
u8 RX2_TimeOut;
u8 Key1_cnt;
u8 Key2_cnt;
bit Key1_Flag;
bit Key2_Flag;
u8 RX2_Buffer[UART2_BUF_LENGTH]; //接收缓冲
void LinInit();
void LinSendMsg(u8 lid, u8 *pdat);
void LinSendHeader(u8 lid);
void UartInit(void)
P_SW1 = (P_SW1 & 0x3f) | 0x00; //USART1 switch to, 0x00: P3.0 P3.1, 0x40: P3.6 P3.7, 0x80: P1.6 P1.7, 0xC0: P4.3 P4.4
SCON = (SCON & 0x3f) | 0x40;
T1x12 = 1; //定时器时钟1T模式
S1BRT = 0; //串口1选择定时器1为波特率发生器
TL1 = TM;
TH1 = TM>>8;
TR1 = 1; //定时器1开始计时
SBUF = dat;
while(TI==0);
TI = 0;
char putchar(char c)
UartPutc(c);
return c;
u8 i;
EAXFR = 1; //扩展寄存器(XFR)访问使能
CKCON = 0; //提高访问XRAM速度
P1M1 = 0x32; P1M0 = 0x32; //设置P1.1、P1.4、P1.5为漏极开路(实验箱加了上拉电阻到3.3V), P1.1在PWM当DAC电路通过电阻串联到P2.3
TR0 = 1; //Tiner0 run
Lin_ID = 0x32;
UartInit();
LinInit();
EA = 1; //打开总中断
SLP_N = 1;
TX_BUF[0] = 0x81;
TX_BUF[1] = 0x22;
TX_BUF[2] = 0x33;
TX_BUF[3] = 0x44;
TX_BUF[4] = 0x55;
TX_BUF[5] = 0x66;
TX_BUF[6] = 0x77;
TX_BUF[7] = 0x88;
if(B_1ms) //1ms到
B_1ms = 0;
if(!P32)
if(!Key1_Flag)
Key1_cnt++;
if(Key1_cnt > 50)
Key1_Flag = 1;
LinSendMsg(Lin_ID, TX_BUF); //发送一串完整数据
Key1_cnt = 0;
Key1_Flag = 0;
if(!P33)
if(!Key2_Flag)
Key2_cnt++;
if(Key2_cnt > 50)
Key2_Flag = 1;
LinSendHeader(0x13); //发送帧头,获取数据帧,组成一个完整的帧
Key2_cnt = 0;
Key2_Flag = 0;
if(RX2_TimeOut > 0) //超时计数
if(--RX2_TimeOut == 0)
for(i=0; i<RX2_Cnt; i++) printf("0x%02x ",RX2_Buffer); //从串口输出收到的从机数据
RX2_Cnt = 0; //清除字节数
printf("\r\n");
B_1ms = 1; //1ms标志
// 函数: void LinSendByte(u8 dat)
// 描述: 发送一个字节函数。
// 参数: none.
// 版本: VER1.0
// 日期: 2021-10-28
// 备注:
B_TX2_Busy = 1;
S2BUF = dat;
while(B_TX2_Busy);
// 函数: u16 LinSendData(u8 *pdat)
// 描述: Lin发送数据函数。
// 参数: *pdat: 设置数据缓冲区.
// 返回: Lin ID.
// 版本: VER1.0
// 日期: 2021-10-28
// 备注:
void LinSendData(u8 *pdat)
u8 i;
for(i=0;i<FRAME_LEN;i++)
LinSendByte(pdat);
// 函数: void SendBreak(void)
// 描述: 主模式发送Lin总线Break函数。
// 参数: none.
// 版本: VER1.0
// 日期: 2021-10-28
// 备注:
USART2CR5 |= 0x04; //主模式 Send Break
LinSendByte(0x00);
// 函数: void LinSendPID(u8 id)
// 描述: ID码加上校验符,转成PID码并发送。
// 参数: ID码.
// 版本: VER1.0
// 日期: 2020-12-2
// 备注:
u8 P0 ;
u8 P1 ;
P0 = (((id)^(id>>1)^(id>>2)^(id>>4))&0x01)<<6 ;
P1 = ((~((id>>1)^(id>>3)^(id>>4)^(id>>5)))&0x01)<<7 ;
LinSendByte(id|P0|P1);
// 函数: void LINSendChecksum(u8 *dat)
// 描述: 计算校验码并发送。
// 参数: 数据场传输的数据.
// 版本: VER1.0
// 日期: 2020-12-2
// 备注:
u16 sum = 0;
u8 i;
for(i = 0; i < FRAME_LEN; i++)
sum += dat;
if(sum & 0xFF00)
sum = (sum & 0x00FF) + 1;
sum ^= 0x00FF;
LinSendByte((u8)sum);
// 函数: void LinSendHeader(u8 lid)
// 描述: Lin主机发送帧头函数。
// 参数: ID码.
// 版本: VER1.0
// 日期: 2021-10-28
// 备注:
SendBreak(); //Send Break
LinSendByte(0x55); //Send Sync Field
LinSendPID(lid); //设置总线ID
// 函数: void LinSendMsg(u8 lid, u8 *pdat)
// 描述: Lin主机发送完整帧函数。
// 参数: lid: Lin ID; *pdat: 发送数据缓冲区.
// 版本: VER1.0
// 日期: 2021-10-28
// 备注:
LinSendData(pdat);
LINSendChecksum(pdat);
// 函数: void LinSetBaudrate(u16 brt)
// 描述: Lin总线波特率设置函数。
// 参数: brt: 波特率.
// 版本: VER1.0
// 日期: 2021-10-28
// 备注:
u16 tmp;
tmp = (MAIN_Fosc >> 4) / brt;
USART2BRH = (u8)(tmp>>8);
USART2BRL = (u8)tmp;
// 函数: void LinInit()
// 描述: Lin初始化函数。
// 参数: none.
// 版本: VER1.0
// 日期: 2021-10-28
// 备注:
void LinInit()
S2_S = 1; //USART2 switch to: 0: P1.0 P1.1, 1: P4.6 P4.7
S2CON = (S2CON & 0x3f) | 0x50;
AUXR |= 0x14; //定时器2时钟1T模式,开始计时
ES2 = 1; //允许中断
LinSetBaudrate(Baudrate); //设置波特率
S2CFG |= 0x80; //S2MOD = 1
USART2CR1 |= 0x80; //LIN Mode Enable
USART2CR5 &= ~0x20; //LIN Master Mode
// LinSendMsg(Lin_ID, TX_BUF); //Send data
// 描述: UART2中断函数。
// 参数: nine.
// 版本: VER1.0
// 日期: 2014-11-28
// 备注:
void UART2_int (void) interrupt 8
if(S2RI)
S2RI = 0; //Clear Rx flag
if(RX2_Cnt >= UART2_BUF_LENGTH) RX2_Cnt = 0;
RX2_Buffer[RX2_Cnt] = S2BUF;
RX2_Cnt++;
RX2_TimeOut = 5;
if(S2TI)
S2TI = 0; //Clear Tx flag
B_TX2_Busy = 0;
