58-LIN总线从机收发测试-USART2,STC32G12K128实验箱演示程序,STC32G8K64,STC32CL8K64
主程序main.C代码如下(汇编版本在附件中):
本例程基于STC32G为主控芯片的实验箱进行编写测试。
USART类型Lin从机总线收发测试用例,默认通信脚:P4.6 P4.7.
收到一个非本机应答的完整帧后通过串口1输出, 并保存到数据缓存.
收到一个本机应答的帧头后(例如:ID=0x12), 发送据进行应答.
3秒内没收到新的数据,MCU进入休眠状态,通过LIN总线唤醒.
默认传输速率:9600波特率, 用户可自行修改.
下载时, 默认时钟 24MHz (用户可自行修改频率).
#include "..\comm\STC32G.h"
#include "stdio.h"
typedef unsigned char u8;
typedef unsigned int u16;
typedef unsigned long u32;
#define MAIN_Fosc 24000000UL
#define Baudrate 9600UL
#define TM (65536 -(MAIN_Fosc/115200/4))
sbit SLP_N = P7^7; //0: Sleep
#define FRAME_LEN 8 //数据长度: 8 字节
#define UART2_BUF_LENGTH 16
u8 StaCR;
u8 Lin_ID;
u8 TX_BUF[8];
bit B_1ms; //1ms标志
u16 msSecond;
bit B_RX2_Flag; //接收标志
bit B_TX2_Busy; //发送忙标志
u8 TX2_Cnt; //发送计数
u8 RX2_Cnt; //接收计数
u8 RX2_TimeOut;
u8 RX2_Buffer[UART2_BUF_LENGTH]; //接收缓冲
void LinInit(void);
void LinStatusRead(void);
void LinSendData(u8 *pdat);
void LINSendChecksum(u8 *dat);
void UartInit(void)
P_SW1 = (P_SW1 & 0x3f) | 0x00; //USART1 switch to, 0x00: P3.0 P3.1, 0x40: P3.6 P3.7, 0x80: P1.6 P1.7, 0xC0: P4.3 P4.4
SCON = (SCON & 0x3f) | 0x40;
T1x12 = 1; //定时器时钟1T模式
S1BRT = 0; //串口1选择定时器1为波特率发生器
TL1 = TM;
TH1 = TM>>8;
TR1 = 1; //定时器1开始计时
SBUF = dat;
while(TI==0);
TI = 0;
char putchar(char c)
UartPutc(c);
return c;
u8 i;
EAXFR = 1; //扩展寄存器(XFR)访问使能
CKCON = 0; //提高访问XRAM速度
TR0 = 1; //Tiner0 run
Lin_ID = 0x32;
UartInit();
LinInit();
EA = 1; //打开总中断
printf("STC32G USART2 to LIN Test Programme!\r\n");
SLP_N = 1;
TX_BUF[0] = 0x81;
TX_BUF[1] = 0x22;
TX_BUF[2] = 0x33;
TX_BUF[3] = 0x44;
TX_BUF[4] = 0x55;
TX_BUF[5] = 0x66;
TX_BUF[6] = 0x77;
TX_BUF[7] = 0x88;
if((B_RX2_Flag) && (RX2_Cnt >= 2))
B_RX2_Flag = 0;
if((RX2_Buffer[0] == 0x55) && ((RX2_Buffer[1] & 0x3f) == 0x12)) //PID -> ID
LinSendData(TX_BUF);
LINSendChecksum(TX_BUF);
if(B_1ms) //1ms到
B_1ms = 0;
msSecond++;
if(msSecond >= 3000) //3秒钟没收到数据进休眠
msSecond = 0;
P27 = 1; //LED17 OFF
PD = 1; //Sleep
P27 = 0; //LED17 ON
if(RX2_TimeOut > 0) //超时计数
if(--RX2_TimeOut == 0)
msSecond = 0;
printf("Read Cnt = %d.\r\n",RX2_Cnt);
for(i=0; i<RX2_Cnt; i++) printf("0x%02x ",RX2_Buffer); //从串口输出收到的数据
RX2_Cnt = 0; //清除字节数
printf("\r\n");
B_1ms = 1; //1ms标志
// 函数: void LinSendByte(u8 dat)
// 描述: 发送一个字节函数。
// 参数: none.
// 版本: VER1.0
// 日期: 2021-10-28
// 备注:
B_TX2_Busy = 1;
S2BUF = dat;
while(B_TX2_Busy);
// 函数: u16 LinSendData(u8 *pdat)
// 描述: Lin发送数据函数。
// 参数: *pdat: 设置数据缓冲区.
// 返回: Lin ID.
// 版本: VER1.0
// 日期: 2021-10-28
// 备注:
u8 i;
for(i=0;i<FRAME_LEN;i++)
LinSendByte(pdat);
// 函数: void LINSendChecksum(u8 *dat)
// 描述: 计算校验码并发送。
// 参数: 数据场传输的数据.
// 版本: VER1.0
// 日期: 2020-12-2
// 备注:
u16 sum = 0;
u8 i;
for(i = 0; i < FRAME_LEN; i++)
sum += dat;
if(sum & 0xFF00)
sum = (sum & 0x00FF) + 1;
sum ^= 0x00FF;
LinSendByte((u8)sum);
// 函数: void LinSetBaudrate(u16 brt)
// 描述: Lin总线波特率设置函数。
// 参数: brt: 波特率.
// 版本: VER1.0
// 日期: 2021-10-28
// 备注:
u16 tmp;
tmp = (MAIN_Fosc >> 4) / brt;
USART2BRH = (u8)(tmp>>8);
USART2BRL = (u8)tmp;
// 函数: void LinInit(void)
// 描述: Lin初始化函数。
// 参数: none.
// 版本: VER1.0
// 日期: 2021-01-05
// 备注:
void LinInit(void)
S2_S = 1; //USART2 switch to: 0: P1.0 P1.1, 1: P4.6 P4.7
S2CON = (S2CON & 0x3f) | 0x50; //8位数据,可变波特率, 允许接收
AUXR |= 0x14; //定时器2时钟1T模式,开始计时
ES2 = 1; //允许中断
LinSetBaudrate(Baudrate); //设置波特率
S2CFG |= 0x80; //S2MOD = 1
USART2CR1 |= 0x80; //LIN Mode Enable
USART2CR5 |= 0x20; //LIN Slave Mode
USART2CR5 |= 0x10; //AutoSync
// 描述: UART2中断函数。
// 参数: nine.
// 版本: VER1.0
// 日期: 2014-11-28
// 备注:
void UART2_int (void) interrupt 8
if(S2RI)
S2RI = 0; //Clear Rx flag
StaCR = USART2CR5;
if(StaCR & 0x02) //if LIN header is detected
B_RX2_Flag = 1;
if(StaCR & 0xc0) //if LIN break is detected / LIN header error is detected
RX2_Cnt = 0;
RX2_Buffer[RX2_Cnt++] = S2BUF;
if(RX2_Cnt >= UART2_BUF_LENGTH) RX2_Cnt = 0;
RX2_TimeOut = 20;
USART2CR5 &= ~0xcb; //Clear flag
if(S2TI)
S2TI = 0; //Clear Tx flag
B_TX2_Busy = 0;
