25-高级PWM1-PWM2-PWM3-PWM4,驱动P6口呼吸灯实验程序,STC32G12K128实验箱演示程序,STC32G8K64,STC32CL8K64
主程序main.C代码如下(汇编版本在附件中):
本例程基于STC32G为主控芯片的实验箱进行编写测试。
高级PWM定时器 PWM1P/PWM1N,PWM2P/PWM2N,PWM3P/PWM3N,PWM4P/PWM4N 每个通道都可独立实现PWM输出,或者两两互补对称输出.
8个通道PWM设置对应P6的8个端口.
通过P6口上连接的8个LED灯,利用PWM实现呼吸灯效果.
PWM周期和占空比可以根据需要自行设置,最高可达65535.
下载时, 选择时钟 24MHz (用户可自行修改频率).
#include "stdio.h"
typedef unsigned char u8;
typedef unsigned int u16;
typedef unsigned long u32;
#define MAIN_Fosc 24000000UL
#define PWM1_0 0x00 //P:P1.0 N:P1.1
#define PWM1_1 0x01 //P:P2.0 N:P2.1
#define PWM1_2 0x02 //P:P6.0 N:P6.1
#define PWM2_0 0x00 //P:P1.2/P5.4 N:P1.3
#define PWM2_1 0x04 //P:P2.2 N:P2.3
#define PWM2_2 0x08 //P:P6.2 N:P6.3
#define PWM3_0 0x00 //P:P1.4 N:P1.5
#define PWM3_1 0x10 //P:P2.4 N:P2.5
#define PWM3_2 0x20 //P:P6.4 N:P6.5
#define PWM4_0 0x00 //P:P1.6 N:P1.7
#define PWM4_1 0x40 //P:P2.6 N:P2.7
#define PWM4_2 0x80 //P:P6.6 N:P6.7
#define PWM4_3 0xC0 //P:P3.4 N:P3.3
#define ENO1P 0x01
#define ENO1N 0x02
#define ENO2P 0x04
#define ENO2N 0x08
#define ENO3P 0x10
#define ENO3N 0x20
#define ENO4P 0x40
#define ENO4N 0x80
#define PWM_PERIOD 1023 //设置周期值
bit B_1ms; //1ms标志
u16 PWM1_Duty;
u16 PWM2_Duty;
u16 PWM3_Duty;
u16 PWM4_Duty;
bit PWM1_Flag;
bit PWM2_Flag;
bit PWM3_Flag;
bit PWM4_Flag;
void UpdatePwm(void);
EAXFR = 1; //扩展寄存器(XFR)访问使能
CKCON = 0; //提高访问XRAM速度
PWM1_Flag = 0;
PWM2_Flag = 0;
PWM3_Flag = 0;
PWM4_Flag = 0;
PWM1_Duty = 0;
PWM2_Duty = 256;
PWM3_Duty = 512;
PWM4_Duty = 1024;
// Timer0初始化
TR0 = 1; //Tiner0 run
PWMA_CCER1 = 0x00; //写 CCMRx 前必须先清零 CCxE 关闭通道
PWMA_CCER2 = 0x00;
PWMA_CCMR1 = 0x60; //通道模式配置
PWMA_CCMR2 = 0x60;
PWMA_CCMR3 = 0x60;
PWMA_CCMR4 = 0x60;
PWMA_CCER1 = 0x55; //配置通道输出使能和极性
PWMA_CCER2 = 0x55;
PWMA_CCMR1 |= 0x08; //开启PWMA_CCRx预转载功能(需要CCxE=1才可写)
PWMA_CCMR2 |= 0x08;
PWMA_CCMR3 |= 0x08;
PWMA_CCMR4 |= 0x08;
PWMA_ARRH = (u8)(PWM_PERIOD >> 8); //设置周期时间
PWMA_ARRL = (u8)PWM_PERIOD;
PWMA_ENO = 0x00;
PWMA_ENO |= ENO1P; //使能输出
PWMA_ENO |= ENO1N; //使能输出
PWMA_ENO |= ENO2P; //使能输出
PWMA_ENO |= ENO2N; //使能输出
PWMA_ENO |= ENO3P; //使能输出
PWMA_ENO |= ENO3N; //使能输出
PWMA_ENO |= ENO4P; //使能输出
PWMA_ENO |= ENO4N; //使能输出
PWMA_PS = 0x00; //高级 PWM 通道输出脚选择位
PWMA_PS |= PWM1_2; //选择 PWM1_2 通道
PWMA_PS |= PWM2_2; //选择 PWM2_2 通道
PWMA_PS |= PWM3_2; //选择 PWM3_2 通道
PWMA_PS |= PWM4_2; //选择 PWM4_2 通道
PWMA_BKR = 0x80; //使能主输出
PWMA_CR1 |= 0x81; //使能ARR预装载,开始计时
P40 = 0; //给LED供电
EA = 1; //打开总中断
while (1);
void timer0(void) interrupt 1
if(!PWM1_Flag)
PWM1_Duty++;
if(PWM1_Duty > PWM_PERIOD) PWM1_Flag = 1;
PWM1_Duty--;
if(PWM1_Duty <= 0) PWM1_Flag = 0;
if(!PWM2_Flag)
PWM2_Duty++;
if(PWM2_Duty > PWM_PERIOD) PWM2_Flag = 1;
PWM2_Duty--;
if(PWM2_Duty <= 0) PWM2_Flag = 0;
if(!PWM3_Flag)
PWM3_Duty++;
if(PWM3_Duty > PWM_PERIOD) PWM3_Flag = 1;
PWM3_Duty--;
if(PWM3_Duty <= 0) PWM3_Flag = 0;
if(!PWM4_Flag)
PWM4_Duty++;
if(PWM4_Duty > PWM_PERIOD) PWM4_Flag = 1;
PWM4_Duty--;
if(PWM4_Duty <= 0) PWM4_Flag = 0;
UpdatePwm();
// 函数: UpdatePwm(void)
// 描述: 更新PWM占空比.
// 参数: none.
// 版本: V1.0, 2012-11-22
PWMA_CCR1H = (u8)(PWM1_Duty >> 8); //设置占空比时间
PWMA_CCR1L = (u8)(PWM1_Duty);
PWMA_CCR2H = (u8)(PWM2_Duty >> 8); //设置占空比时间
PWMA_CCR2L = (u8)(PWM2_Duty);
PWMA_CCR3H = (u8)(PWM3_Duty >> 8); //设置占空比时间
PWMA_CCR3L = (u8)(PWM3_Duty);
PWMA_CCR4H = (u8)(PWM4_Duty >> 8); //设置占空比时间
PWMA_CCR4L = (u8)(PWM4_Duty);
